Need help with Tentlabs power supply - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd April 2006, 02:57 PM   #1
gy21 is offline gy21  Netherlands
Send a message via MSN to gy21
Default Need help with Tentlabs power supply
I need some help with this power supply. I only get 2.63 V on pin 8.
I feed this circuit with 12.5 Volt, after the 7808 I measure 8 Volts. At the B of the transistor I measeare 3.2V The collectorhas 8 Volts.
If I measure straight over the 22k resistor (not from ground) I get 4,75V. If I measure straight over the 56k resister I get 3,2 Volts Wich is ofcourse the same as the basis at the transistor.
What am I doing wrong here?
Hifi Setup: http://my.hifi.nl/?user=1651
Music Collection: http://www.hilbimuziekcollectie.tk
Old 22nd April 2006, 04:06 PM   #2
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: Need help with Tentlabs power supply
Blown transistor ? Have you tried changing it ?
Old 22nd April 2006, 04:12 PM   #3
float is offline float  England
Just change the 22k for 2.2k and the 56k for 5.6k. That should sort it. Tip courtesy of Guido himself.
HTH
I w isH i cuold typpe bettr
Old 22nd April 2006, 06:22 PM   #4
HTH
Yup that fixed it.
Thanks Float!
P.s. I Got 4.6V now, is that close enough to 5 V that is needed for the clock to work correctly?
Old 22nd April 2006, 07:50 PM   #5
I read on the tentlabs site that the clock needs 5V +-5%. So that means 4,6V is to low.
Any suggestions to raise this voltage? Raising the 5,6K?
Old 22nd April 2006, 09:30 PM   #6
I'd adjust the res's to suit; the dac spec calls for 4.7-5.3v.
I got 5.01v when I built mine; maybe the transistor's slightly out of spec?
Also see here can't get 5V from tent clock XO sch
Old 23rd April 2006, 09:17 AM   #7
ok, lowered the 2k2 res to a 1k5.
got 5.15 now on pin 8.
that should do it I think.
thanks for your help Float.
MachMat or Tentlabs Heater Supply for 300B eeyore Tubes / Valves 6 4th July 2007 01:34 PM
4V Tentlabs filament supply ianc13 Tubes / Valves 2 22nd March 2007 08:02 PM
filament supply: batteries v TentLabs? rick57 Tubes / Valves 24 10th September 2006 10:56 AM
Selling Tentlabs XO Supply Ruach Swap Meet 0 3rd July 2006 06:56 AM
Copyright 1999-2017 diyAudio
