| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm looking to convert a DAC to run off a battery supply (car audio). My victim is an old Cambridge Audio Dacmagic2, I will be doing some of the upgrades outlined in the thread on this forum, but I also want to run it off a +12V supply (which IMHO is probably not a bad thing).
So I'm guessing I need to junk everything before the PSU bridge rectifiers, I'll leave good diodes in place to protect from stupidity (a.k.a. powering with reverse polarity) and add plenty of capacitance to smooth any ripples in the 12V supply, it will then be regulated down to +5v (IIRC) and I'll add more decent quality smoothing caps. should this work? am I missing anything? is it stupid? is therelikely to be any sonic benefit of a DC powersource? thanks. |
#2 |
you have to check the voltage level that comes off those rectifiers in the DAC. If it is considerably lower than 12V DC, you may need to add heat sinking to the regulators on the DAC board that follow the rectifier diodes. If it's more than 12V you will have to use two batteries in series and then you still need make sure that the regulators can handle bringing down 24V to 15 or whatever is needed inside the DAC. Temperature is the main issue if you can't closely match the original DC level with the battery.
Peter |
| Battery supply. | harwoodspark | Analog Line Level | 10 | 23rd December 2007 05:28 PM |
| Converting DV-563 to battery | percy | Digital Source | 0 | 23rd September 2006 12:06 AM |
| Converting this power supply to 127VAC (not the mains) | -_nando-_ | Power Supplies | 6 | 31st May 2006 04:48 PM |
| converting M-Audio SuperDAC to 12v DC supply | jv8 | Digital Source | 5 | 30th December 2003 05:28 PM |
| Battery Supply Help. | RichardJones | Solid State | 4 | 11th June 2003 02:23 PM |
| Page generated in 0.06792 seconds (71.57% PHP - 28.43% MySQL) with 10 queries |
