Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th August 2006, 08:40 PM   #31
WmAx is offline WmAx  United States
If you still just want DD decoding, might I suggest that you look for a used Harman Kardon AVR55. You can probably score one for $75-$130 from ebay, and it has very low noise/clean output from the pre-amp outputs. I don't know why you would want to, but it's also very easy to tap into the analog feed and bypass the amplifier modules in this product. It has easily accessible series of ribbon wires feeding the amplifier modules.
-Chris
Old 7th August 2006, 12:29 AM   #32
Originally posted by Nigel Goodwin
Assuming it's just the same signal that's coming out of the speaker outputs?, then you just need a low pass filter - but as it's at a low level you can filter it much more effectively using an opamp filter.
Yes, it would be the same signal as the final output but simply a lower voltage which could be filtered by an opamp.
I have the diagram for my Sony SACD player and the final stage is an opamp driven by a CXD9675 DAC.
The DAC sends an inverting and an non-inverting signal to each opamp, but I have no idea if this signal is a pulse width modulated type (like the signal fed to the CXD9646 chip referred to above) or a simple analog signal. If this opamp is in fact a low pass filter, then it would serve as a good model for my PRE-OUT interface.
Thanks for your suggestion.
Old 7th August 2006, 12:46 AM   #33
-Chris
Just to show how hard it is for me to decide on which receiver to hot rod, a local store has a second hand Yamaha receiver with pre-outs already built into it selling for $300.
So I did some research on this model and among over 100 reviews from owners, it became clear that the power amp section was lacking (I would be bypassing that anyway), and the DSP does not always convert stereo into multi-channel surround with the best of results.
In the end, I concluded that I what I really wanted was a receiver which had the same quality and features as my Sony SACD/DVD player which has on-board DD/DTS decoding, Bass management, and a great surround sound DSP for converting stereo to 5.1.
I believe that the Sony STR-DG500 receiver has all of these advantages for $300 or less and this appears to be my best choice at the moment.
It seems that this model STR-DG500 does not have the same chips as the European receiver that we have been discussing in this thread. Most likely it has traditional analog power amps inside and I would have to take a fresh look at its schematic diagram before proceding.
One advantage with the STR-DG500 is that I might not need to build a low pass filter for each channel as would be required if the chosen receiver used the CXD9646 power amp chip.
Old 7th August 2006, 10:11 AM   #34
The STRDG500/600 has discrete output transistors, with driver IC's, but according to the manual it doesn't have line level decoded outputs - but it does have multi-channel inputs for an external decoder.
Nigel Goodwin
Old 7th August 2006, 05:54 PM   #35
Nigel,
Thanks for your update.
My problem is I have no external decoder and because I need to decode the SPDIF output of my high definition cable box, I need to purchase a receiver which has a good quality internal Dolby decoder. Because I do not have a sub-woofer (my three 15" Tannoys generate all the Bass that I need), the receiver must also have a good DSP so I can configure my unique combination of speakers correctly. Fortunately, the STR-DG500 can do all this and more.
But I want to keep on using my external high quality power amplifiers, so I need to tap the 5.1 signals within the receiver and re-route them to the exterior.
Originally, any receiver which included your CXD9646 chip looked like a good choice for me, but now I realize that this chip only comes with more expensive receivers and transforming the PWM format signal into analog requires building a number of low pass op-amp filters.
Going with the STR-DG500 seems to be a better option for me, and from what I have learned today, the dual pre-driver ICs appear to be easy to tap into. There is also an internal buffer for the sub-woofer output which serves as a good model.
Like with any mod that creates pre-outs, I will have to make sure there is no thump in my speakers when I power up the receiver. Normally this is accomplished by adding a mechanical relay in series with the pre-out signals.
This receiver sells in Canada for $300 or less plus VAT, about twice the price of a Creative (Soundblaster) External Dolby decoder for which I have no proof of the sound quality.
Thanks for taking the time to answer.
Old 2nd May 2007, 03:44 PM   #36
According to several reviews, the output power of the STR-DG700 goes down with multichannel input - as low as 5 W / channel. Sounds like either too small a transformer or heavy RL filtering before the reservoir caps.
What kind of driver IC and output transistors are used?
Old 2nd May 2007, 06:14 PM   #37
The STR-DG800 and STR-DG500 use the UPC2581 driver IC.
They both use complimentary MN2488 and MP1620 output transistors, which appear to be darlington types.
The plus/minus power supply voltage is 56V for the model 800 and 53.7V for the model 500 chassis.
The power transformer feeds directly to a dual rectifier bridge followed by a 10,000 micro cap on each pole. There does not appear to be any RL filtering.
If this receiver gets starved for power when all 5.1 channels are being driven, I would conclude that it is the power transformer that is undersized for peak demands.
I have my parts gathered for 5 pre-out buffer amps that will tap the driver ICs, but I will not start the construction until the 12 month Sony warranty is expired.
Old 3rd May 2007, 05:52 AM   #38
Thanks, that saves me having to buy one to find out. I would propably have to redo all output stages, so then it might be easier to stay with my Onkyo and add a variable digital delay IC.
Old 3rd May 2007, 05:55 AM   #39
The power reduction stated in two articles sounds too much to be attributable to filtering or an inadequate transformer. Maybe something in the circuit reacts strangely to slighlty reduced supply voltage?
Old 3rd May 2007, 01:15 PM   #40
Following each power stage is a DC detector circuit and an overload detector circuit. After these are mechanical relays to cut the outputs to the speaker terminals.
I can't say if the detector circuits merely switch off the relays or cause the DSP to lower the volume going to the power amplifier, or both.
It would be nice to know exactly what the laboratory testing this receiver observed when all 5.1 channels were driven.
When the volume level was raised, did the output waveform begin to clip, or did the waveform remain clean but the voltage level was automatically reduced to keep the average power to all channels from rising above a threshold?
Adding Preouts to a Pioneer Receiver LightwaveDude Parts 5 14th July 2007 12:50 AM
PC3-08 Pin outs Wynand Car Audio 0 18th May 2005 08:33 AM
ins and outs set Subwoofers 7 16th February 2005 01:31 AM
Adding pre-outs into a processor with separate internal amp? NUTTTR Solid State 0 3rd January 2005 11:50 AM
Adding a pre-out to receiver Dave Bullet Solid State 9 13th January 2003 08:13 PM
Page generated in 0.13989 seconds (79.75% PHP - 20.25% MySQL) with 11 queries
