Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st April 2006, 07:10 PM   #1
jax8308 is offline jax8308  United States
Default Njoe Tjoeb upsampler and balanced output
According to the documentation, the Njoe Tjoeb 4000 upsampler converts the balanced signal to single ended with a transformer. Since I use balanced inputs on my preamp, I would like to leave the signal balanced and eliminate another conversion step.
This is from the manual:
Once in 192/24, the digital signal goes to a high quality double balanced D/A converter chip, which is surrounded by an extremely low noise power supply for maximum resolution and sound quality. Its balanced output signal is converted to single-ended by a proprietary purpose designed audio transformer, that proved to be superior to all solid-state solutions that we examined during extended listening tests. This transformer incorporates various design features, like a special iron core that has never been used before in audio, but proved to be very suitable. Also we used careful impedance matching and balanced windings to obtain optimum bandwidth extension, flattest frequency response, and lowest distortion figures.
Does this make sense or is it a waste of time ?
Old 21st April 2006, 08:25 PM   #2
phn is offline phn  Sweden
phn's Avatar
Speaking as a single-ended guy, yes, it makes sense to me. That even though I doubt there will be any sonic difference.
I'm also a vinyl junkie, and I hate to unbalance the inherently balanced MC cartridge. So I can relate.
The rational is the enemy of sense and reason.
Old 21st April 2006, 08:55 PM   #3
It is a good idea to keep the transformer. It helps to limit the HF garbage produced by delta sigma dacs.
Old 22nd April 2006, 04:47 PM   #4
phn's Avatar
Agreed. The trafo should stay. Lift the ground, or whatever the correct tech lingo is.
AH NJoe TJOEB, valve compatibility issue emperor Tubes / Valves 5 14th November 2007 03:56 AM
AH Njoe Tjoeb CD player, valve Compatibility emperor Digital Source 0 13th November 2007 05:15 PM
Ah Njoe Tjoeb 4000 problem emperor Tubes / Valves 9 30th October 2007 05:06 PM
Upsampler for Njoe Tjoeb - theory of operation rsrphotos Digital Source 2 2nd April 2004 06:46 PM
Njoe Tjoeb 4000 vs RESPONSE AUDIO Signature CD-25 Tube Modified HDCD Player scientist1 Digital Source 1 5th January 2004 08:13 AM
Page generated in 0.07067 seconds (70.28% PHP - 29.72% MySQL) with 10 queries
