Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st April 2006, 01:23 AM   #1
percy is offline percy  United States
Default Can jitter cause hiss ?
Recently I was fooling around with my old(er) Sony discman (D-191) that I had purchased about 6-7 yrs ago. I pulled out the transport mechanism and applied some vibration damping material to whatever areas I possibly could, including the motors and the lens carraige. The one biggest difference I noticed after doing this mod was that before there used to be a very obvious background hiss while playing which is now as good as gone. The only thing that I can think of is that the vibration damping helped reduce jitter caused due to mechanical vibrations. But I have no way of verifying. Could this be possible ? Could jitter cause hiss ? If so then what is the technical explanation for this ?
Old 21st April 2006, 01:15 PM   #2
macboy is offline macboy  Canada
It is more likely that a dirty or corroded electrical connection was cleaned up as a side effect of disconnecting and reconnecting it.
Old 21st April 2006, 04:27 PM   #3
nope didnt remove any connectors, had enough room with the wires connected, once the transport was off its three rubber grommet feet.
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
Hiss but no hum... RockysDad Tubes / Valves 13 5th April 2009 05:35 PM
Hiss in my P3a Amp blap0220 Solid State 15 1st June 2007 01:52 AM
hiss jaudio Chip Amps 21 6th March 2005 05:02 PM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
Page generated in 0.06832 seconds (80.05% PHP - 19.95% MySQL) with 10 queries
