Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th April 2006, 08:40 PM   #1
Default Best methods for I/V conversion?
So, from what I understand there are at least three main ways to do I/V conversion at the DAC output stage:
1) (active) using op-amps and feedback
2) (passive) resistor
3) (passive) transformer
I'd like to hear what your preferences are (pros and cons) and why? Also, what are the DAC specifications that I need to take into account when making this decision?
Old 19th April 2006, 09:13 PM   #2
Uchi Deshi's Avatar
Comparation there is here.
Old 20th April 2006, 01:06 AM   #3
00940 is offline 00940  Belgium
You forget active with discrete output stages and no feedback.
- The opamp solution is easy and gives good enough results if the opamps are good.
- The active path with no feedback gives very good results at a reasonable price (costs less than the best opamps for sure) but it's a bit more work to adjust the I/V stage.
- I never was really happy with passive and just a resistor. Anytime I tried it (single tda1545-tda1543), the simple discrete active I/V suggested by rbroer performed better.
- Transformers based I/V are too expensive for my taste, never tried them.
Ben.
Old 20th April 2006, 02:37 AM   #4
I didn't forget, I'm just not that knowledgeable
Anyway, that sounds interesting. Do you know of any specific threads or web sites discussing this?
Old 20th April 2006, 07:34 AM   #5
wenye is offline wenye  China
Send a message via MSN to wenye
Agree with Ben.
Active I/V all way be the best in resonable cost.
Risistor can not get right performance.
Because of when output voltage from dac close to 0.6V, the internal protecting diode will become turn on and it will cause too more distortion products.
For risistor I/V, if you don't want to have any additional distortion with internal diode, then the output voltage from dac have to lower then 300mV. For a 20bit dac, it mean the lsb will be 0.286uV! It's too low.....
So, please go to the best way for I/V --- active I/V
Old 20th April 2006, 08:41 AM   #6
This is the most classical topic on the subject : Easy-to-build I/V stage
Rbroer made quite a few variations for the tda154* chips :
Simple I/V for TDA1541
"Super-Pair" I/V for TDA1543
Less simple I/V for TDA1541
Single rail, active I/V for TDA1543, TDA1545A
Simple ACTIVE I/V for TDA1543
For balanced output, there's of course the multiple variations on the D1 I/V stage, from Nelson Pass, a search should give you a lot.
Another way to do the I/V is to use some special chips, see Pedja's website. Never tried that myself : http://users.verat.net/~pedjarogic/a...a_dac_home.htm
Ben.
Old 20th April 2006, 12:57 PM   #7
Thanks, 00940. That should keep me going for a while.
Old 20th April 2006, 02:14 PM   #8
I did a little research. Would something like OPA633 (operating open loop) in series with a resistor work?
on the job teaching methods.... unclejed613 Everything Else 1 12th April 2009 10:39 PM
Bias methods? Psychobiker Tubes / Valves 8 3rd April 2008 10:07 PM
Veneering methods KennyBradley Multi-Way 55 11th December 2006 12:46 PM
Balanced amp methods PWatts Solid State 6 26th June 2003 05:17 AM
water methods PWatts Multi-Way 0 25th June 2003 11:46 AM
Page generated in 0.10401 seconds (76.86% PHP - 23.14% MySQL) with 10 queries
