Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th April 2006, 04:12 AM   #1
Default USB to I2S?
I was thinking about building a Hag USB.... I could use it's audio out for awhile, and then I could switch over to an external DAC (Peter's premium probably). Well Peter's DAC accepts I2S which is not confentational with Jitter right?
Here is a double check
Does this unit run off of I2S?
No. It only outputs the standard S/PDIF format. No machine out there has I2S outputs. Or inputs, for that matter.
My understanding is this is the only way to go for getting a digital signal out of USB with out jitter issues...
That is a popular myth floating around the DIY forums.
jh
Old 19th April 2006, 05:26 AM   #2
dsavitsk's Avatar
The only chips I know of that output i2s from usb are the pcm2706 and pcm2707. They are pretty simple to use: here are a few projects I've done.
Tda1541a Nos-usb-dac
http://www.ecp.cc/NOS-USB-DAC.html
As for the jitter myth, there has been some good discussion over at diyhifi.org
Old 19th April 2006, 03:28 PM   #3
pburke is offline pburke  Germany
USB-I2S with PMC2707:
http://www.dddac.de/ma_dac32.htm
Works like a charm on my older TDA1543 DAC, and you can use it on its own, although I wasn't very impressed with the built-in A-D.
Peter
Page generated in 0.05844 seconds (72.72% PHP - 27.28% MySQL) with 9 queries
