| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
i am just building my first own DAC, consisting of a Yamha YM3434 and two AD1860s, but it doesn't work yet. I want to put in the I2S code from the receiver-chip, a SAA7310. the first prolem i encountered was, that the YM3434 wants right-justified data (word-clock changes after data-word) , but the SAA7310 puts out left-justified data (word-clock changes at beginning of data-word) . So i built a little circuit to delay the word-clock. Now it changes at the end of a data-word (seen on my scope), but i still hear mainly/only digital noise. is this due to jitter? any suggestions what to do? thanks in advance! regards, znarfomat |
#2 |
I2S data is not quite left justified. The MSB is occupies the second bit cell after the transistion of WSAB/FSYNC/LRCLK. If you do not take that into account you will be one bit off.
#3 |
thanks for your reply rfbrw!
the problem is, that according to the ym3434 datasheet, the word-clock (of input) changes after the LSB of a data-word. i observe this on my scope too, but still i hear only noise. however, sometimes when i change the duty-cycle and alignment of the word-clock, i can hear a bit of music. unfortunately the datasheet is too big for an attachment. i will try to post the timing diagram only. regards, znarfomat |
#4 |
here is the YM3434 timing diagram.
#5 |
Are you sure the problem is at the SAA7310/YM3434 interface? Is the YM3434 set to output 16 or 18 bit data ?
#6 |
no, i'm not sure if this connection (ym3434 - saa7310) is (still) the problem.
but i think i had to align the word clock and data as shown in the datasheet. and while doing this i sometimes heard some (bad) sound come out of one of the dacs. sound always came from one of the dacs, never from both at the same time. the YM3434 is set to put out 18 bit. what else could be the problem? |
#7 |
What frequency is master clock?
#8 |
i have kwak clock at 12.?? MHz. i used the crystal from my cdp, a Philips cd610.
the clock is fed to SAA7310 and YM3434. |
#9 | |
If it is the case that the MCLK frequencies are mismatched you will have to derive the correct frequencies from a single source. |
#10 |
thank you rfbrw,
the clock seems to be the problem. but i hope, as it is stated in the datasheet, that the ym3434 will work at any frequency between 400 Fs and 20MHz. otherwise i will take my PMD100, as it operates at 256FS. ![]() regards, znarfomat |
| looking for Yamaha YM3434 filters... | moray james | Solid State | 0 | 2nd November 2008 03:04 AM |
| looking for Yahama YM3434 filter... | moray james | Parts | 0 | 2nd November 2008 03:03 AM |
| Add SPDIF on SAA7310/TDA1543 Combination | Tubeee | Digital Source | 7 | 20th July 2004 03:57 PM |
| Help : Marantz CD52 HF signal to SAA7310 <1Vp-p | tbklbl | Digital Source | 2 | 5th January 2004 09:12 AM |
| ym3434 datasheet..where can i find or does anyone have it?pls help. | tone | Digital Source | 1 | 24th October 2002 05:59 AM |
| Page generated in 0.10294 seconds (78.71% PHP - 21.29% MySQL) with 11 queries |
