Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th April 2006, 12:57 PM   #1
Lourens is offline Lourens  Europe
Default Sony CDP-557 ESD erratic behaviour
Dear all,
Seeking for some help solving strange problems with my brothers 557 (in original state).
First symptoms were: play-back stops without any obvious cause, after some rattling (mechanical) noise from the cdp-mechanism, it slows down to stand-still in a few seconds (music had stopped at the moment the noise started). Display reads: DISC*MEMO.
Starting again sometimes results in uninterrupted playback, but mostly in the same error after about 2-3 minutes.
Moving this heavyweight from his place to mine at first seemed to cure things. It even played on ‘repeat’ successfully for 24 hours or so. But after a few days the same problems popped up again.
Sony Netherlands wasn’t willing to accept the machine for repair (too old.....) nor to provide a service manual as an alternative (not available....).
Next step was to bring it to a well known Dutch repair and modification expert. At his place it played for weeks without any problem at all... He had no clue of what could cause those at other places.
Finally a friend in yet another city gave it a try. First weeks: no problems; then - at intervals: the Disc*Memo obstruction. Thorough cleaning and lubrication of all moving parts seemed to help, but after a few weeks another symptom occurred. Playback was ok, but the drawer didn’t open anymore. Pushing the in-out button only stops play back. Until yesterday, now it plays ok again....
Any suggestions to solve the problems are very welcome!
TIA
Lourens
Old 15th April 2006, 12:49 PM   #2
Default please help!
Nobody?
Of course it also would be really helpful to have a service manual!
best regards
Lourens
Old 15th April 2006, 01:16 PM   #3
Vidalgo is offline Vidalgo  Israel
You can get service manual from here
It's not free, but very cheap.
Hope it will help.
Old 16th April 2006, 06:50 PM   #4
Thanks, Vidalgo!
Ordered it right away.
sjalom
Lourens
Old 16th April 2006, 08:40 PM   #5
Probably, one of microswitches (there are at least 3, in each CD mechanism) sometimes has lossed contact, it's can be aging problem. Only idea.
Also, good point is to check tray motor driver IC. At least visual inspection of solder joints, and overheating check (just with finger).
Time to check electrolytics?
And check your mail
Old 16th April 2006, 08:42 PM   #6
Banned
Send a message via Yahoo to Elso Kwak
New laser?
I have the manual too.
Old 16th April 2006, 09:03 PM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
Here's a tip:
Check for poor solder joint on pin 30 of IC101.
Just blank resolder it, even if it looks good.
/Hugo
Old 16th April 2006, 09:59 PM   #8
Originally posted by Netlist
Here's a tip:
/Hugo
Time bomb?
Old 17th April 2006, 06:51 PM   #9
Netlist's Avatar
At that age, yes. Careful inspection and resoldering of critical components is a must. Voltage regulators, IC's, coils and even normal TO92 transistors are to be redone.
/Hugo
Old 17th April 2006, 07:23 PM   #10
Thanks for all the tips. Will keep you posted!
best regards
Lourens
PTC Behaviour jayam000 Solid State 11 4th May 2009 03:35 AM
Erratic tube activity BudP Tubes / Valves 4 6th March 2008 09:09 PM
Marantz CD5000 erratic playback deburgess Digital Source 7 25th April 2005 07:05 AM
Page generated in 0.09891 seconds (82.80% PHP - 17.20% MySQL) with 11 queries
