Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th April 2006, 06:47 AM   #1
elviukai's Avatar
Question Marantz cd 94 MKII dual or mono opams inside
I just opened my new marantz cd 94 MK II and while I found it very beautiful outside and pretty many great things inside built in from factory - 2 x tda 1541 S1, black gates f series, separate boards, cerafines, few quality relays, the sound is not in the same league as parasound 1500 dac( 4 x pcm 63 in fully balansed push pull mode)- less air ,less transparent less wide, less bass, I noticed cheap op apms(probbaly in those days was not good opas)
this mashine uzses 2 x opas. question is is this dual or single opa? I would like to put burr brown opa 627.
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!..
Old 14th April 2006, 07:23 AM   #2
georgehifi's Avatar
Send a message via MSN to georgehifi
NE5534's x 4. 2 for the i/v stage, and 2 for the output amps. Prime candidate, change all for AD825 (smd) on browndog adapter boards, take out the ne5534's instal ic socketts and insert the browndogs with AD825's on board and listen to how good the old CD94 can sound.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 14th April 2006, 08:57 AM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Hi
Or use AD826 as direct replacement,
Andy
Old 14th April 2006, 08:59 AM   #4
Geoff is offline Geoff  United Kingdom
According to the CD-94 Mk2 service manual, for each channel an NJM4580 (dual) is used for the I/V conversion. This is followed by another NJM4580 for the filter then an NJM5534 for the normal output. The headphone output has an NJM4556.
elviukai
Email me and I will send you a copy of the schematic for the analogue stages.
Geoff
Old 14th April 2006, 09:22 AM   #5
georgehifi's Avatar
You could be right then Geoff as I have the CD94 circuit, I was always led to believe that the only difference was the use of two TDA1541's instead of one for the CD94, and that all else was the same, clearly not the case.
Cheers George
Service Manual Request: Marantz CD75 MkII or CD65 MkII jeff mai Digital Source 9 23rd April 2009 04:48 PM
KrellClone KSA100-MKII 1000VA toroidal transformer for dual mono GB stolbovoy Group Buys 33 16th June 2008 04:39 PM
Inside a Burmester 828 MkII.... NAT.D.BERG Solid State 4 15th April 2007 12:41 AM
Single Mono's or Dual Mono? Tazzy Pass Labs 8 3rd October 2002 02:03 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Page generated in 0.08242 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
