| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
It's a super low jitter modular design. I spend around half a year to design and I just finish the first sample.
I named it "Verse-dair". Performance testing just finished in these few days, the result is very interesting. I compare the spec with CD8414 as following 1. Jitter: "Verse-dair" from 10Hz-1MHz from carrier will be lower than 20ps RMS. "CS8414" from ???KHz--???MHz from carrier (no spec) , typical 200ps RMS. 2. Jitter attenuation range "Verse-dair" From 10Hz-1MHz from carrier >40dB "CS8414" From 20KHz -3dB ~ 1MHz -35dB linear attenuation curve (-6dB / double the frequency) 3. Receiving sampling range: same to CS8414 4. Functionally: pin function compatible with CS8414, pin out compatible with CS8412 in DIP-28 package The modular on the photo is Mr. "Verse-dair" |
#2 |
#3 |
Very interesting. What sample rates does it support?
#4 |
The sampling range that "Verse-dair" can support from 8Khz to 96khz
#5 |
Look like you did a nice job....
As this is a DIY Forum I have immediately 2 questions 1. How does it sound compared with a CS8412/14 2. Can you publish the circuit, so we now what you have been doing ? thanks doede
www.dddac.de Happy listening and building |
#6 | |
diyAudio Moderator Emeritus
It's only audio |
#7 |
Looks like some kind of PLD or FPGA and most likely a commercial 'kit' type product.
#8 | |
Banned
That's a good point. Note the sticker over the chip |
#9 |
Wenye, if you need a volounteer for testing/evaluating the module you can send me one
I am curious how it compares to CS8412.
It's only audio |
#10 |
Banned
Id like to point out , THAT board looks really good well done.
| generate jitter test signal and measurign jitter using AP2? | BJAMR | Digital Source | 11 | 1st November 2010 02:07 PM |
| Mark Levinson DAIR-1 | ALP | Digital Line Level | 8 | 30th April 2009 04:17 PM |
| Cs-8412 (dip) | Icarium | Swap Meet | 2 | 17th August 2008 12:36 PM |
| CS 8414 RS422 Receiver | Sergelisses | Digital Source | 2 | 2nd May 2007 09:26 AM |
| Page generated in 0.08821 seconds (82.04% PHP - 17.96% MySQL) with 11 queries |
