| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
For extracting digital audio from a PC and sending it to a DAC, what would be the best scheme to implement ?
1. An all out integrated USB DAC - like something based on PCM2702(example). 2. Convert USB to I²S and send to an I²S DAC. 3. Convert USB to spdif and send to a spdif DAC. 4. Use a PCI soundcard that has an I²S output (and has bit and rate accurate output i.e. does not resample), then send it to an I²S DAC. 5. same as above except S/PDIF instead of I²S 6. others ? please feel free to suggest any other that might be worth considering. Any tested and tried firewire DAC solutions out there yet btw ? |
#2 |
I would generally prefer I2S connections over SPDIF (correct implementation assumed). You get 1. and 2. in one by using a PCM2707, see e.g. www.dddac.de. If you choose the SPDIF route I would just get one of those external USB audio interfaces that offer digital out via toslink or coax.
#3 |
You can check out this thread for some additional ideas...
http://www6.head-fi.org/forums/showthread.php?t=157955
gravity always wins |
#4 | |
Banned
#5 |
Ulas,
I have absolutely no idea what you are trying to suggest. It will be a diy dac however. |
| digital interface transformer,help | tomat | Digital Line Level | 3 | 4th June 2009 05:10 AM |
| Digital interface chips | lt cdr data | Digital Source | 0 | 16th June 2008 08:44 PM |
| dat-link+ digital audio interface need help | koko | Digital Source | 0 | 10th January 2008 09:07 AM |
| Another digital transformer/interface question | ble0t | Digital Source | 11 | 30th April 2005 03:38 AM |
| digital interface | higrade | Digital Source | 3 | 16th January 2003 12:35 AM |
| Page generated in 0.07946 seconds (76.31% PHP - 23.69% MySQL) with 10 queries |
