Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
D/A Distortion Compensator
Old 11th April 2006, 02:40 PM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default D/A Distortion Compensator
Hello All.
I have a Kenwood DP-1100SG cd player which sounds great, no doubt helped by many items as standard eg twin Transformers, multiple regulators, separate digital / analog boards, cast alloy cdm, etc.
One thing it has is a 'D/A Distortion Compensator' chip, TC17G005AF-0048.
It sits between the digital filter, SM5804D, and the D/A chips, PCM54P-K, with an output feeding the I/V converter for nulling distortion at 1KHz -20dB and 100Hz 0dB.
It looks as though it may reclock the I2S lines.
I have been unable to find any info on this chip.
Can anyone help??
Andy
Old 11th April 2006, 03:26 PM   #2
andrew_whitham is offline andrew_whitham  United Kingdom
andrew_whitham's Avatar
Default glitch = distortion?
Could that be related to the de-glitcher? (pg 7 of the PCM54 datasheet) maybe its a method of achieving that...
Marketing?
Who's the manufacturer of that chip? the TC17G005AF-0048?
Old 11th April 2006, 04:35 PM   #3
poynton's Avatar
Default Re: glitch = distortion?
I don't think so. It uses 2 PCM54 so a deglitcher would not be required.
I don't know !
Andy
Old 11th April 2006, 04:39 PM   #4
poynton's Avatar
CHIP
Old 11th April 2006, 05:18 PM   #5
rfbrw is offline rfbrw
It is a Toshiba gate-array. Half way between a custom ASIC and a FPGA.
Old 11th April 2006, 05:45 PM   #6
poynton's Avatar
OK but how doe's it work?
Andy
Old 11th April 2006, 06:03 PM   #7
Can't tell what it does from that schematic. The dacs, though, are far too small to be PCM54's. Not nearly enough pins. Pretty sure the text says PCM56.
Old 11th April 2006, 06:11 PM   #8
poynton's Avatar
OOPS!
Yes, they are PCM56K
Andy
Old 11th April 2006, 06:18 PM   #9
davidsrsb is offline davidsrsb  Malaysia
This sounds like another attempt at adding a small digital dither signal to the D/A inputs and then subtracting the same signal in analog form at the I/V covertor.
It should work.
D/A Distortion CompensatorHide this!Advertise here!
Distortion at about 6-8K. Shoog Chip Amps 17 25th February 2007 05:41 PM
Bottom octave compensator Dave Jones Multi-Way 10 28th July 2004 11:07 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 03:54 PM
baffle step loss compensator bbaker6212 Multi-Way 1 13th November 2002 11:25 PM
