Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th April 2006, 08:09 PM   #1
Default Bypass digital filter in PCM1794?
The spec sheet for PCM1794 says the internal digital filter can be bypassed. Has anyone used it in this capacity, and wouldn't this be equivalent to a non-OS DAC?
Old 10th April 2006, 08:21 PM   #2
b-square's Avatar
Default Re: Bypass digital filter in PCM1794?
the internal digital filter bypass is used along with an external filter. the data rate is still expected to be based on oversampling of the original input data. there is no mode documented in the data sheet that allows data straight out of a digital receiver to get sent directly to the dac without oversampling.
(reading back over the datasheet, it might be ok to drive WDCK at a "non-OS" rate...other dacs that allow internal DF bypass typically expect the behavior i mentioned above).
bb
Old 10th April 2006, 08:41 PM   #3
I also found that AD1955 could be used in a similar fashion.
Old 10th April 2006, 09:13 PM   #4
What I am thinking is something like CS8414->AD1896->PCM1794 (or AD1955). Therefore, it involves upsampling, which is admittedly not quite the same as a non-OS DAC. However, it does avoid the issue of the brickwall filter at the DAC stage.
Old 11th April 2006, 12:16 AM   #5
You do not avoid anything but one more FIR filter doing this, I'm not sure why you think the ASRC's polyphase FIR filter is less harmful than the integrated DF in the PCM1794, but maybe you could try it both ways and see what you think.
Old 11th April 2006, 03:35 AM   #6
Man, I was thinking about using the PCM1704K, but that chip is expensive! Is it worth the extra cost?
Engine noise, no luck with bypass filter silentblackhat Car Audio 6 30th October 2005 06:57 PM
Bypass Caps for digital IC decoupling ftorres Digital Source 50 26th September 2005 07:24 AM
ps filter cap bypass question? crippledchicken Solid State 5 29th December 2003 08:44 AM
DVD Bypass/Upgrade of digital output from 46 to 96? chris ma Digital Source 7 30th March 2002 04:36 PM
Page generated in 0.08030 seconds (74.56% PHP - 25.44% MySQL) with 10 queries
