| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
hello my old SB live5.1 broken and I need new sound card. I plan to buy yamaha receiver 7.1 . Can you suggest me some sound cards I can use? plan to connect it via coaxial cable(digital in). may I use some cheap soundcard with only 5.1 decoding?How these digital out works?does the sound card decodes sound and than encode again? or it purely passthrough all sound data(in all formats)?
ps. want to use all my speakers (have 7.1 already) many thanks for any advice or explanation |
#2 |
im sure many of you must have solved this problem... we all have pc and watch movies on them so we must have some soundcard in pc. many of us have an external decoder in some receiver and DIY made speakers. Same like me. but the question is: Do I need spend a huge money on super sound card?- that never reaches quality of external decoder? well my system
many thanks for any help |
#3 |
Hi. If all you need is unprocessed digital output, you can try the Chaintec AV-710. It is very cheap. Do a search on head-fi.org to learn more about this card.
#4 |
Soundcard passes the unaltered ac3/dd/dts/whatever stream to the receiver which decodes it. There is no way to pass unencoded multichannel over spdif (not enough bandwidth).
Only when the computer generates the multichannel sound (I guess there are games capable of that) it has to do the encoding. Either way soundcard shouldn't make noticeable difference. As a note, I built a spdif coax output for my onboard sound (in my part of the world it's a bit difficult to order the original backside connector for digital out) and I'm very pleased with it. |
#5 |
Thanks for help. I seareched Chaintec AV-710 and found a lot of useful information. But I cant buy it in my republic
fortunately found another solution. So if anyone has same problem buy Prodigy 7.1 LT its more expansive but not a bad buy.reason: it fully supports AISO ("ASIO is a high end feature that playsback audio without any resampling; hence it's pure and unmolested") exactly what I wanted ps. chaintech it has also |
#6 | |
if it is correct than why there is some AISO standart? I realy would like to understand these things |
#7 |
I don't know any AISO
If you are referring to ASIO these are low latency drivers (needed mostly if you compose / mix music) http://www.soundblaster.com/resource...id=53937&cat=3 --- If you have a digital connection between the sound card and the receiver, the receiver will decode anything it recognizes (pcm, dts, ac3), computer just needs to pass the bitstream. |
| Improving sound card digital section - beginner questions | halcyon | Digital Source | 3 | 21st November 2005 12:39 PM |
| IDE CD-ROM to sound card signal - digital or analog ? | percy | Digital Source | 6 | 6th August 2005 02:47 PM |
| With a 5.1 sound card, do I still need a Dolby Digital decoder? | JCoffey | Digital Source | 14 | 30th April 2004 02:10 PM |
| Dolby Digital 5.1 amp for Sound Card | dracul | Everything Else | 3 | 29th August 2003 04:37 AM |
| Digital sound card for HIFI | lykkedk | Digital Source | 1 | 26th December 2002 10:20 AM |
| Page generated in 0.09589 seconds (76.06% PHP - 23.94% MySQL) with 10 queries |
