diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Graphic VFD module - Preamp Update (http://www.diyaudio.com/forums/digital-source/7726-graphic-vfd-module-preamp-update.html)
mhennessy 17th November 2002 05:15 PM
Hi All,
I've just bought one of these new Noritake-Itron graphic VFD's to replace the 20-by-2 text display in my preamp. It's early days yet, but I thought you'd like to see a few pictures...
http://www.mhennessy.f9.co.uk/preamp..._progress1.jpg
http://www.mhennessy.f9.co.uk/preamp/graphic_vfd2.jpg
http://www.mhennessy.f9.co.uk/preamp/graphic_vfd3.jpg
The display I bought is an LCD-compatible unit - GU140X16G-7806 - that shares the same physical dimensions with the old text unit. It even works in 4-bit mode, which meant it dropped straight into the preamp with no hardware modifications of any sort... :)
This is a nice unit which I recommend. Farnell sell them in the for about £35. Check out my homepage for a few more detailsÖ
jleaman 17th November 2002 05:49 PM
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
I WANT ONE sniff snifff WAAAA SNIFF SNIFF
id like to build a desplay-pre amp
how long have yu been working on that preamp.?
LOOOKKSS AWSOME i love it.
Jason
Pjotr 17th November 2002 07:26 PM
Hi mhennessy,
£35 is really a bargain. Iíll check them out at Farnell. Do they have a serial mode also, comparable to the character ones?
Btw nice home page :cool:
Chaio, peter
BrianGT 18th November 2002 01:09 AM
Looks great! I haven't done too much with my vfd yet. Great job on the pre-amp again. I have changed my design away from the PGA2310, as it didn't seem to clean, and moved to a design similar to the Pass Labs P1.7A volume control (service manual at: http://www.passlabs.com/pdf/aleph/apserv17.pdf ), integrated with a Balanced Zen Line Stage ( http://www.passdiy.com/pdf/balzenpre.pdf )
Brian
mhennessy 18th November 2002 04:54 PM
Hi Jason,
Glad you like it! It seems like I've been working on it for ages now, but I only really get the chance to work on it at weekends... While it's basically finished, there's still quite a lot to do to the software before it goes into service.
Yes - the display also has a serial interface. You choose between sync or asych. Handy when you're running out of IO on your micro...
BrianGT: How are you getting with your preamp? I had a look at some pictures on your site last week - any more to follow soon?
Next project - some monoblock power-amps... just need to take a year off work ;)
jwb 18th November 2002 05:42 PM
How do you get the nice lettering on your front panel? Was it done by an outside shop? What is the technique?
Also I wonder if you would be willing to release your PIC software for the quadrature control.
BrianGT 18th November 2002 06:00 PM
I have been putting time getting my monoblocks finished first, but I am getting them pretty close, so I am going to put more time into them. Where did you get those great looking buttons on the front?
I should put some pictures up soon, hopefully.
Brian
mhennessy 19th November 2002 05:58 PM
2 Attachment(s)
Hi jwb,
The labels are rub-down transfers. I'm just using some old ones that I bought from Maplin many years ago, which I've found survive quite well compared to the usual lettering that you can buy from a stationary shop. Maplin don't seem to stock them any more, unfortunately.
You've got to be really careful when applying them if you want good results - it took me nearly 4 hours! The final result is ok, but I won't be publishing a close-up shot!
Hi Brian,
I'll be looking out for more info on your monoblocks! I've rescued 4 old power supplies from an old sound-desk, and they come in perfect cases for monoblock amps. I might make 4 and bi-amp! The plans are fairly advanced, but just in my head at the moment...
For some info about the switches, check out this thread... (towards the bottom of the page)
Copyright ©1999-2017 diyAudio
