| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi, I'm looking for the above transport but to no avail. I managed to find 1202 & 1204. Is the 1204 is compatible with 1205? and if it yes, any mod to be done?
Between 1202 & 1205 which one is better? |
#2 |
There are a few VAM1205s available from a chap in Germany, they're quite good (will post contact details when I've found the url again)
The VAM 1205 is basically the VAM1204 (CDM12.4, same thing) but with a brushless disc motor. So - buy the 1204 and swap the laser block into your existing '1205. I've done this, and mate has duplicated the swap blind (by email) with 100% success. |
#3 |
Martin,
Thanks for your reply. I'm using Naim CD5, shouldn't be a problem right? |
#4 |
No, it's the same '1205 just as used in the CD3.5 - on which we've successfully done the 12.4laser-into- VAM1205 swap. Take your time disassembling the tray assembly, make notes/take pics, you'll be fine. Try not to touch the exposed contacts on the flexfoil /laser assembly when handling though - these are very sensitive to static and it's easy to damage the photodiode assembly before you even begin (true for all laser mechs BTW).
Here's the VAM1205 link: http://www.ersatzteil.justone-schnep...05_mechan.html -Sebastian is good to deal with and the part (which looks like it maybe a high quality Chinese copy) works just fine in Naim CD3.5s. Hope this helps! |
#5 |
Thanks martin....!
#6 |
Martin, are you with acoustica?
How's bath?. Is it still cold now?. I'll be going to London on the 9/4. Infact almost every month I'll be in London...cheers. Thanks for your info once agian, really appreciate that. |
#7 |
Yes , yes and yes - but briilliant sunlight this week
Cheers, M. |
#8 |
Martin,
I bought already the VAM1204, just about 7 pounds!! and it's a high quality chinese made but the laser block is 100% the same. But what is the different between the TDA1305 (VAM 1205) & TDA 1302 (VAM 1204) if I were to change the laser block. Any effect to sound quality? Thanks |
#9 |
This thread is a bit old, but I guess it is still relevant.
I am looking for a VAM1205 or VAM1204 to replace my VAM1205 mech from a Meridien CD player. No luck so far. However, the shop says that the VAM1250 laser assembly should be able to work as well.: http://www.agencies.com.sg/cdpickup%...W.O%20MECH.htm Mechanically, it seems to fit, but the two lazer assembly do look different. The VAM1205 has a TDA1302 IC on the flex, but this 1250 does not appear to have an IC ( maybe under the shield ). So had anyone tried successfully to use the VAM1250 laser on the VAM1205? |
#10 | |
the IC under the shield is the successor (CDRW compatible) of the TDA1302 In this case also this thread (post #8) could be of interest: new Brand of Hologram Laser (LDGU) LT0H30PA inside by Philips CDM12 and VAM12 mech |
| Vam 1205 /vam1250 / Cdm12.5 | jmmartins | Digital Source | 1 | 1st January 2010 05:44 PM |
| Naim DBL | diy guy | Multi-Way | 2 | 23rd February 2008 02:04 AM |
| FS Naim IXO | chris maw | Swap Meet | 2 | 22nd November 2007 07:34 AM |
| Where to buy CDM 12.5 (aka VAM 1205) | memorylane | Digital Source | 1 | 11th May 2005 06:51 PM |
| Naim SL2 | richie00boy | Multi-Way | 0 | 28th September 2004 09:33 AM |
| Page generated in 0.10809 seconds (76.96% PHP - 23.04% MySQL) with 10 queries |
