diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   USB-I2S-TDA1543 kit (http://www.diyaudio.com/forums/digital-source/77093-usb-i2s-tda1543-kit.html)
jkeny 4th April 2006 10:56 AM
USB-I2S-TDA1543 kit
I just received audioworkshops AW-D3 kit. http://www.audioworkshop.com.hk/index_en.htm
After reading posts about problems here and in Audioworkshops forums about the J2 jumper settings for I2S operation - I was wondering has anybody else built one of these?
I nvestigated & came up with a plan, which might work.
I decided that I would dispense with the options allowed by the jumpers and wire it permanently for I2S mode & self powered.
This is relatively simple for I2S - just leave out R7 100k res which feeds 3.3V to FSEL (this leaves FSEL low=I2S mode)
This is not so easy for self powered mode - PSEL is connected to 3.3V and this line has to be cut and routed to ground (PSEL low=self powered).
Has anybody tried this - what do you think - would this solve I2S issues?
John
Copyright 1999-2017 diyAudio
