Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd April 2006, 02:00 PM   #1
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
Default Simple, ugly DAC
i just made the PCM2707 work to get i2s from USB.
I am not looking at anything fancy, i just want a USB input on my DIY Tube amp. I have AD1852/3 and AD1955 to get it to audio.
Can the AD1955 be implemented without the serial programming?
Bas
Old 4th April 2006, 04:49 AM   #2
andrei is offline andrei  Canada
Well, PCM2707 has an analog output (although it is fairly crappy from looking at the datasheet). You'll need MCU to program AD1955, but it comes up in I2S configuration by default, so it is probably can be interfaced with PCM2707. Another Alternative is PCM1794, which has hardware control.
Old 4th April 2006, 11:08 AM   #3
beamnet's Avatar
I am currently leaning towards the internal DAC for simplicity, as al the DAC's require big output circuitry.
Or is there a possible 1 opamp I/V or so? Don't need the high pass, as it won't pass my output transformer anyway
Bas
Old 4th April 2006, 11:54 PM   #4
You can do I/V conversion with a single differential THS4130/OPA1632 opamp per channel. Or you could do passive I/V convesion with a step-up transformer...
Ugly face contest Circlotron The Lounge 144 16th October 2011 12:31 PM
Ugly DC-DC SMPS CHACALPOWERS Car Audio 4 25th December 2008 05:11 AM
OPT -the good, the bad or the ugly ?? AuroraB Tubes / Valves 1 9th February 2007 11:07 PM
Ugly, but versatile, new amp tubelab.com Tubes / Valves 24 5th October 2006 01:01 PM
coyote ugly Bernhard Digital Source 4 16th April 2004 07:45 PM
Page generated in 0.06963 seconds (77.09% PHP - 22.91% MySQL) with 10 queries
