| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Banned
It seems the favorite DAC chip around here is the TDA1543 and everybody who has heard it raves about it, especially when multiple chips are stacked or paralleled. You know what they say: "If it sounds to good to be true, it probably is."
I recently purchased a Lite DAC-AH (eight parallel TDA1543) and gave it a listen. In a word: it’s BAD, e.g., not good. OK, it’s only $175, but it is still doesn’t sound good. The sound is coarse, crude, and congested. No detail, air, or finesse. Compared to an Audio Note DAC 1.2, it just doesn’t measure up. Of course, the AN costs hundreds more. Even compared to a stock ART DI/O, which costs less than the DAC-AH, the DAC-AH falls flat. Ordinarily I don’t care for the sound of digital filters but in this match-up I prefer the DI/O. An additional annoyance is the DAC-AH emits a constant squeal all by itself without being plugged into an amplifier. The DAC-AH measures poorly, too. Here is the DAC-AH (upper trace) side by side with the DI/O (lower trace). 689.0625 Hz sine wave @ 0 dB The problem is not in the output stage because I see the same thing looking at the top of the I/V resistor. 689.0625 Hz triangle wave @ 0 dB With the TDA1543, a triangle wave looks more like a sine. 689.0625 Hz sine wave @ -7 dB At -7dB the distortion is diminished. 689.0625 Hz triangle wave @ -7 dB It appears the TDA1543's linearity falls off rapidly beyond 15 bits. I know a lot of you believe jitter is the most important aspect of a DAC’s performance. Here are 0-25K Hz FFT plots of Julian Dunn’s jitter-test signal. DAC-AH DI/O Finally, here are traces and plots of a 5512.5 Hz sine wave @ 0dB. 5512.5 Hz sine wave @ 0 dB DAC-AH DI/O With all the added harmonic and enharmonic noise, it’s easy to see why the DAC-AH sounds as bad as it does. I can’t say I’m disappointed with the DAC-AH because I really wasn’t expecting very much. It’s just one more in my growing collection of reference DACs. Now I know what the TDA1543 sounds like and have a reference to better judge other’s opinions about it and similar DACs. |
#2 |
I did listen to one once but i didn't think it was that bad.
and no, i didn't buy one. I was looking for a unit i could play(practise) with mods on. is this a copy of doede's 1543 dac? ps, not pcb layout. If so, are you saying the concept doesn't work or the pcb/parts. etc layout? have you done a comparison with other 1543 dac's allan
Indecision makes the world gone round. Maybe |
#3 |
I think the point is that the very heart of the Lite-dac, the TDA1543, is dire.
#4 |
If your daft enough to put a sub £100 dac up against a £1000 one what else are you going to hear ?
You need to compare dac's of equal merit ...regardless of chip type. What transport was used, was it the same for both dac's ? I'm not here to defend the AH, but just to point out the daft nature of the comparison. Would you compare a mini and a jaguar and complain the mini doesn't go as fast ? |
#5 | |
i had a mini don't knock them, they were so much fun. allan ps dac thingy is this a dac-ah bad design or implementation? if so, why does it sound better(more detail) than a standard cdplayer? rfbrw this person is wrong then? http://www.dddac.de/
#6 |
I'm just saying its an unfair comparison.....of course the AH will sound bad......90% of all dacs will be put to shame by the audio note.
I'm currently listing to a MF - dac3 against the DAC-AH the AH is streets ahead in clarity imaging and dynamics. My task is to get the MF dac to out perform the AH ,as it should being about 4x the cost. I'm not knocking Mini !! just saying you would not quotes its spec against an E types and complain the minis too slow ! |
#7 |
#8 | ||
Magneto the Gravity Man
Hi. Looking at the sine output, I would say that it could be either of awpagan's suggestions. The waveform is asymmetrical and something appears to be limiting rather than clipping, given the shape. Power supply problem? Andy |
#9 | |
In this case it is all about chip type. The TDA1543 is dire. It is dire in the £100 Lite dac and it is dire in the circa £800 Shigaraki. |
#10 | |
maybe we should give up. and all go out and buy a 800+ pound dac that does not sound like DIY ideals to me. allan
| shinOBIWAN/Zaph personality clash | chubby chaser | The Lounge | 2 | 19th May 2008 07:21 PM |
| ZEN vs GOLIATH (the giant guy) | Trist | Pass Labs | 3 | 22nd December 2001 05:36 AM |
