Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd April 2006, 03:12 PM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Default BNC connectors - clamp on or twist on?
I have never used BNC connectors before but want to make up some digital cables.
What are the pros and cons of using the clamp-on type of BNC plug and the twist-on types?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 2nd April 2006, 04:28 PM   #2
tubenut is offline tubenut  South Africa
tubenut's Avatar
Pros/cons...
The one requires a crimping tool and is quicker to terminate, the other does not, just a spanner/wrench and soldering iron for centre core...
I think (dunno for sure) that the crimp type is better giving gas tight bonding with no poor solder for signal to travel through.
I do not own a crimp tool either but take my own cable to a "computer cable custom shop" where some ladies sit and crimp RG58 and 59 all day in between soldering VGA cables.
The labour charge is not bad and they supply the BNC, if they duff it, they supply the new plug
Here in SA I pay about USD5.00 for 2 BNCs fitted this way....
Guillaume
Croak Audio Exploration
Old 2nd April 2006, 04:41 PM   #3
phn is offline phn  Sweden
phn's Avatar
A boring answer on a DIY forum, but buy a ready-made cable. How much is it, €10? You will never be able to make anything better than that.
"If the use of an exotic cable makes a DAC sound better, then the DAC is not performing adequately and should be repaired or redesigned." -- John Watkinson, Resolution magazine.
Heater circuit - to twist or not to twist Rob11966 Tubes / Valves 19 20th July 2008 02:08 AM
Tube speaker with a twist hybridfiat Multi-Way 2 2nd June 2008 10:48 PM
Deep HT Sub With a Twist bjackson Subwoofers 15 8th August 2006 07:41 PM
which wires to twist? Matttcattt Chip Amps 30 1st July 2003 10:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
