Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
schmetic of pcm1704
schmetic of pcm1704
Old 25th November 2002, 06:32 AM   #11
hill is offline hill
hill's Avatar
Originally posted by nFORCE
Hi Sir,
How about BB DIR1703 + AD1895 + AD1853 circuit connection.
The DIR1703 is too difficult to make all kind of sampling frequency.
If I only need 44.1/ 16 bit --> (up convert by 1895) to 192/24
How to connect.
Many Thanks.
nFORCE
Hi, nFORCE,
Connection of what u said is so easy. But the point is why u wanna do the upconvert(44.1-->192) ? It's useless to AD1853.
Digital filter of AD1853 will auto-scaling with the input data rate. For 32k-48k sampling data it's 8x oversampling, to 88.2-96k it's 4x oversampling, to 176.4-192k it's 2x oversampling. My mean is there is no advantage to upconvert the sampling rate to 192k for ad1853.
In this case the only advantage of ASRC is jitter isolation. If u wanna use a low jitter clock oscillator for ASRC chip.
So, my suggestion is convert the input sampling rate to 88.2k for cd playback.
I had built a dac with cs8414--cs8420--sm5847--pcm1702 last year. I using the cs8420 to convert every sampling rate into 44.1k. I'd try 48k, 88.2k, 96k. Do u know what i found out?
For cd playback, 44.1K is the best sampling rate of ASRC output!!!
BTW, how can u buy DIR1703?
I have cs8414, cs8420, SM5843, SM5847, PCM1702, PCM1704, AD1853, I wanna try DIR1703. Could u help me?
I change therefore I am.
Old 25th November 2002, 05:39 PM   #12
pquadrat is offline pquadrat  Germany
jwb:
I am happy to be of service. Schematic shows CS8420 reciever, DF1704, balanced stereo PCM 1704, and passive I/V conversion stage.
I am currently drawing the schematics for a DAC with 8420/DF1704/PCM1704, but I can not see the CS8420 on Your drawing. All pins of the leftmost IC in Your drawing have different names
than in the data sheet have . What did I miss?
all:
I am planning to build this set with the output stage of Nelson Pass' D1 converter. Any suggestions? I did read most of the related comments on this forum, and the PCM1704 seems to be top choice, but I am not sure about the SCR (CS8420 or AD1896+Receiver?)
peter
Old 25th November 2002, 05:58 PM   #13
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
I apologize! This schematic is actually using Burr-Brown DIR1703 for the receiver. I must have been confused. I will post the CS8420 schematic when I get home this evening.
Old 25th November 2002, 06:28 PM   #14
skaara is offline skaara  Slovenia
jwb:
So this is dir1703-df1704-pcm1704 schematic (if its that its useful to me, because i cant get cs8420 here?
What are the differences between dir1703 and cs8420?
And whats the difference between df1704 and df1706 (i have some of these, and if there is a difference ill get df 1704), are pins the same with these two chips and connections and parts in our schematic are the same when using df1706?
Old 25th November 2002, 06:40 PM   #15
jwb's Avatar
Hi skaara. Sorry I didn't ever answer your email. I'm lazy.
Originally posted by skaara
jwb:
Yes.
CS8420 includes a sample rate converter, while DIR1703 does not. However, both can be used for low-jitter SPDIF-to-serial receivers.
Also I think the DIR1703 is easier to integrate into the circuit because it requires fewer external parts.
The DF1706 runs from 3.3V supply. The DF1704 runs from 5V. As far as I know the 1706 is simply an evolution of the 1704. They are almost pin compatible if you use the correct voltage supply and pay attention to the x4 pin, which needs to be engaged for 192kHz operation.
Old 25th November 2002, 07:16 PM   #16
Jocko Homo is offline Jocko Homo  United States
Banned
The main difference seems to be the lack of pull-up/down resistors in the '06 to reduce current drain.
Jocko
Old 25th November 2002, 07:27 PM   #17
jwb's Avatar
haha oops. you really have to read those footnotes to keep those B-B guys from sneaking one by you.
Old 25th November 2002, 08:55 PM   #18
So the df1706 is better than df1704?
Old 26th November 2002, 02:41 AM   #19
nFORCE is offline nFORCE  Japan
Send a message via ICQ to nFORCE
OK, let exchange.
Are you live in China? I goto Shenzhen every week.
Please email to me for details, if you can leave your mobile phone no, that good, +86 136XXXXXXX right?
I have 20 pcs of DIR1703 on hand. I can use 3-5 pcs for exchange.
nFORCE
Originally posted by hill
Hi, nFORCE,
Old 26th November 2002, 07:17 AM   #20
hill's Avatar
Exchange?
Aha, good idea.
I live in Guangzhou China.
Could u tell me which model u're interesting in?
cs8414, cs8420, ad1853, sm5847, or......
schmetic of pcm1704Hide this!Advertise here!
music angel kt88 tube amp schmetic needed keithgreenhalgh Tubes / Valves 55 4th December 2016 09:17 PM
Where to buy PCM1704? m_buzzi Digital Source 3 11th November 2004 12:53 PM
Pcm1704 hacknet Digital Source 5 11th April 2004 09:25 PM
MAT 02/03 amplifier schmetic needed esl Solid State 31 24th September 2003 09:30 PM
