Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
cd laser replacement info needed
Old 2nd April 2006, 04:26 AM   #1
ocaukrell is offline ocaukrell  Australia
Default cd laser replacement info needed
Have a luxman dz-03 that has a dieing laser, I can get the part ok, (kss152a) but are there any tricks or traps I should know about when replacing it ?
Will it need any form of alignment ?
Etc ?
Old 2nd April 2006, 05:08 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Should only have to desolder the anti-static solder blob and fit it and away you go. Just have to watch out for static so be careful.
No longer DIY active
Old 2nd April 2006, 10:49 PM   #3
Mkay, thats what I thought, thanks for that, have a good week.
Old 2nd April 2006, 11:46 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
You may need to align it. E-F balance especially. Touch up Focus Offset. The gains should be close, you don't want to mess with those.
How's your disc motor?
-Chris
Old 2nd April 2006, 11:55 PM   #5
All else seems fine, other than a dead draw belt.
how would I do the E-F and focus ?
Have old bwd dual trace 50mg cro, fluke 77, few other simple bits.
Just ordered the replacement laser (kss152a is now a toph7833), should have it tomorrow.
Any other faults I should be pre-fixing in this model ?
Thanks..
Old 3rd April 2006, 12:01 AM   #6
anatech's Avatar
Hi ocaukrell,
E-F balance is a pain, you need the manual ... or Pierre Verrany test discs. Your 'scope would work fine but you need to know how to set it up.
The disc motor bearings are normally worn by now. Th edisc table hieght is critical. Measure it to the nearest mm before touching anything. From the mechanism base to the top of the table.
Do you have any service info for this unit? If you aren't familiar with doing this, you can try to stick the head in, but if you know a good tech (on CD's, not TV's !!!) he can touch it up for you.
-Chris
Old 3rd April 2006, 12:10 AM   #7
Have zero info, service job, cust loves this unit so I said i'd try.
first time i've replaced a laser.
If it appears to work ok after the replacement, how critical is it to do the align ?
Disc table hight, is this from bottom of laser assembly to top of the assembly that holds the laser assembly etc ?
Old 3rd April 2006, 12:19 AM   #8
anatech's Avatar
Hi ocaukrell,
Disc table height is measured from the metal sub chassis where the guide rails and motor are mounted, to the top of the disc table.
Alignment is very important. When the unit is aligned properly the sound quality is much improved, as is tracking ability.
Did you clean and relubricate the guides for the head. KSS-152A was plastic with no bearings I think. Failure to lubricate will wear out any guide, but plastic will go really fast.
-Chris
Old 3rd April 2006, 12:38 AM   #9
Ok so the pic shows the table hight, correct ?
As per photo, haven't touched it yet (yuch).
Yes will be cleaning and greasing before new one goes in.
If it makes a difference to sound, could I do small (tiny) adjustments by ear ???
Yes, I know not the best but still.
Old 3rd April 2006, 12:56 AM   #10
anatech's Avatar
Hi ocaukrell,
Yes, that is the correct measurement.
No, there is no way you can align anything by ear alone. Once you have experience you can listen to the servo noise, and watch the 'scope.
From the looks of that, it will need a really good cleaning. Simple transport though.
-Chris
cd laser replacement info neededHide this!Advertise here!
Laser replacement CD-7 Marantz D.A.R.R.Y.L. Digital Source 3 13th November 2013 07:55 PM
KSS151A...Laser replacement.... Lyra Digital Source 8 10th June 2013 07:45 PM
TEAC VRDS-T1 Laser replacement HELP NEEDED!! vodz Everything Else 7 4th April 2011 11:48 PM
CDM4 laser replacement giuseppe_catani Digital Source 1 3rd February 2004 08:45 PM
Laser replacement.... Lyra Digital Source 4 2nd February 2004 11:17 AM
Copyright ©1999-2017 diyAudio
