Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th March 2006, 06:37 PM   #1
dsavitsk's Avatar
Default Tda1541a Nos-usb-dac
Don't know if anyone else has done this yet, so I thought I'd post a picture. There is space for an async reclocker, but I didn't hook it up yet. otherwise, schematic is what you might expect: PCM2707 -> TDA1541A -> Passive I/V -> AD8620. Size is 3.5" x 2.8". Decoupling caps are BG 0.1uF NX. The other 6 are under the board. Sound is pretty good, better than my own TDA1543 based NOS-USB-DAC.
Old 1st April 2006, 08:07 AM   #2
How's the sound compared to the pcm2707 output?
Old 1st April 2006, 07:45 PM   #3
dsavitsk's Avatar
Much better. No comparison, really. I don't think the Vout on the pcm270* or pcm290* sound that good in the first place, but the tda1541a in a nos setup is really quite pleasing.
Old 2nd April 2006, 11:00 AM   #4
Terry Demol's Avatar
Default Re: Tda1541a Nos-usb-dac
hi dsavitski
Well done.
What is the clocking arangement for usb into PCM2707 and how
jitter prone is it.
I haven't looked deeply into usb dac's but am definately interested
in building one for personal use (PC sound).
Terry
Old 3rd April 2006, 03:39 AM   #5
Nice work dsavitsk, well done! Web site looks nice as well.
Extreme_Boky
Old 3rd April 2006, 07:54 AM   #6
dsavitsk's Avatar
Default Re: Re: Tda1541a Nos-usb-dac
jitter prone is it.
Well, there are 2 clocks. One is the async reclocking, which I have not tried yet, so I don't know. I just copied Yeo's schematic. http://diyparadise.com/asynchreclocker.html
For the pCM2707's clock, I just used a standard crystal. I know some people (like the DDDAC) use a high quality oscillator, but the PCM2707's datasheet seems to suggest that this isn't the best thing to do. Because there is no way to turn off the internal oscillator, it seems that all you can do is make it worse. I have not taken measurements or done any comparisons, so I don't know what the right answer is. It is worth investigating, though.
Old 5th April 2006, 01:01 AM   #7
Send a message via AIM to Spasticteapot
That's a pretty nice DAC. How much did it cost you to build?
Also, is that an Atmel microcontroller I see?
Old 5th April 2006, 02:29 AM   #8
dsavitsk's Avatar
Thanks. I think in the $120 range.
Hmmm. Not sure what you are looking at, but no. No microcontroller. I suppose I should post a schematic. There's a messy one at http://www.ecp.cc/images/1541-NOS-USB-DACL.GIF (though I used an AD8620 for the opamp and didn't populate the output filter)
Old 8th April 2006, 03:35 PM   #9
If the following question sounds dumb, please excuse me, in advance. Is it possible to use an ASRC, like the AD1896, in between the PCM2707 and TDA1541, but with bypassing the sample rate conversion in the AD1896? The point would be to use the ASRC only to minimize jitter. I understand the whole idea of a NOS DAC is to avoid filtering/oversampling, so obviously, if the AD1896 filtering cannot be bypassed, this wouldn't make any sense. I've downloaded the spec sheet for the AD1896, but I only gave it a quick lookover. I thought I'd ask first, before wasting too much time on the idea. Thanks! Oh, nice DAC by the way.
Old 12th April 2006, 06:48 PM   #10
Zodiac is offline Zodiac  United States
Hi
I've made a usb dac with the tda1541
see here:
http://www.diyaudio.com/forums/showt...682#post851682
I've since implemented a 12mhz tent clock for the pcm2706 powered off a jung type reg, to be honest I didn't notice that much of a change
It's better than my Discmaster / Benchmark combination and the ease of use definitely wins hands down
// TDA1541A PCB already tube-lover Swap Meet 109 19th June 2010 06:16 PM
Wtb: Tda1541a deskmate88 Swap Meet 0 21st March 2007 12:07 PM
One more TDA1541A DAC HeadSh0T Digital Source 25 7th September 2005 07:26 PM
Page generated in 0.10953 seconds (79.44% PHP - 20.56% MySQL) with 11 queries
