| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello All,
Does such a thing as the subject exist. All I want is 6 or 8 channels of high quality DAC, with a good clock and linux support. I'm slightly reluctant to spend 200 quid on an maudio or similar as you seem to be spending alot of money on stuff you dont' need (mic preamps, input ADCs, SPDIF connector etc.) Thanks for your advice, Thomas Hood |
#2 |
I've been looking and haven't found much. The M-Audio Transit seems cheap enough to try modding. (Not that I know how.)
Best idea I've come up with so far is to concentrate on the front speakers and let the other 4 have 2nd/3rd best, ie. the soundcard DACs. Something like a PC -> HagUsb -> Monica2 -> Charlize for the fronts and feed the rear, sub and centre amps from the soundcard outputs. Anyone got an opinion an how 'vital' sound quality is for the other 4 (or 6) speakers? I'm hoping that as long as the fronts are excellent, having lesser quality DACs feeding the surrounds won't be that noticable. |
#3 |
Why USB ?
#4 |
In my case the front speakers would have to be from USB as the SP/DIF output of my soundcard doubles as the sub/centre analogue out. (The vesajack on the TB Santa Cruz.)
I suppose I could upgrade it but that would divert funds from other projects and I don't see the point of a new card just to get a separate SP/DIF output. |
#5 |
I made one.
I modified a MAudio Revolution (aka Santcruz) sound card to have 3 optical SPDIF outputs. I then made a 6 channel intergrated DAC + bridged Gainclone amp. I used brutefir on the Linux box to do active xovers and room correction which then used 5 of the channels (left low & high, right low & high, sub). All worked very well. Getting more than 2 channels through USB requires custom ICs and drivers at the moment, so i would forget about this option unless you are going to modify someone elses hardware. A few photos... Modified soundcard: One of the three DAC + Bridged gainclone amp boards:
#6 |
HI
Nice work you did there MWP! ![]() I whant to ask you diy folks if this could be done with the one SP/DIF output of my sound card (x-fi)for all 6 channels? I have never build a dac before so if there is a way for me to do this i would like the most simple way to do it Thanks |
#7 |
Very impressive indeed MWP.
This could do the trick for me. Was the DAC amp combo of your own design -- and if so are PCBs (or art) available? How is volume control implemented? Thanks, Thomas Hood |
#8 | |
I own a transit as wel but are still in the experimenting phase. (probably simple capacitor/connector/housing upgrade) Note that the transit is not a 6/8 channel dac although it can "pass through" multichannel DTS edit: there are measurements done of the capacitor upgrade. if of interest I could dig them out of the WWW.
better be indoubt untill you're sure |
#9 | |
The volume control was done via a 2-step relay attenuator on the PCB, and the rest via software. No PCBs available as i made those myself, and the schematics & PCB design files i dont really want to give out. I did have a screen shot of the schematic somewhere, but i cont find it
#10 |
Regards mr. MWP ,this is Vedmitra sharma from Agra India as I have been looking for a method of converting P.C. soundcard into usb to use with laptop .I think you can be a great help for this . I want to convert a Creative 7.1 P.c. sound card into a usb as to record miuniumum 4 tracks simultanously on laptop with cooledit pro or adove audition . If you wish you can send me informatiuo on my e mail id,s vedmitraa@gmail.com or vedmitrsharma@rediffmail.com.thanking you.
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 08:29 AM |
| 4 channel conversion to mono 1 channel | iUSERTLO72p | Car Audio | 24 | 25th October 2007 06:07 PM |
| HELP!: Channel volume very very low, other channel fine. | harrisni | Solid State | 2 | 20th September 2006 12:10 PM |
| My 4 channel car Amp distorting on 1 channel (large pics) | MikeHunt79 | Car Audio | 9 | 3rd September 2003 07:41 AM |
| Help quick! 4 Channel > 2 Channel? | zmoz | Car Audio | 3 | 5th July 2003 09:48 PM |
| Page generated in 0.10613 seconds (89.65% PHP - 10.35% MySQL) with 10 queries |
