| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm playing on making a CS4334 dac board to mount in an old cd player in the future. From the datasheet it follows that if no SCK signal is detected on pin 2 then an internal SCK is generated by dividing Master clock by 2 else the device operates with the external SCK signal. Which one is the better option internal or external SCK ? I was thinking of leaving pin 2 floating or grounded, and using flip-flops just before the dac. http://www.cirrus.com/en/pubs/proDat...5-38-39_F3.pdf http://www.cirrus.com/en/pubs/rdDatasheet/cs4334eb.pdf http://sound.westhost.com/project85.htm |
#2 |
easier to make
#3 | |
#4 | |
Datasheet says that internal and external are identical if external clock is syncronised with LRCLK (WS). It would be fed by a saa7310 so I don't know if that would be the case! How would you recommend connecting the dac ? |
#5 |
A more pertinent question would have been "Which one of the two options will work?" Internal SCK will not work.
#6 | |
Will order the bits today.. |
| A good starter project? CS8415-CS4334 | astouffer | Digital Source | 2 | 17th March 2008 10:44 PM |
| CS4334 Noise | nevelo | Digital Source | 4 | 15th April 2004 12:51 PM |
| CS8414 and CS4334 - 4sale | R. McAnally | Swap Meet | 0 | 26th January 2002 02:26 AM |
| Page generated in 0.08964 seconds (75.84% PHP - 24.16% MySQL) with 11 queries |
