Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd March 2006, 03:12 AM   #1
Xlrator is offline Xlrator  United States
Default PGA2310 and Basic Stamp not responding
I have a PGA2310 Stereo Audio Volume Control socketed on a perfboard and connected to my Basic Stamp 2 according to the datasheet, but I still cannot get any response from it. With the code below I am trying to send straight binary to it. 16 bits, the first 8 for Right channel and last 8 for Left channel. I also tried this method:
volume_1 = %00011001 'channels step #25
LOW 7
PAUSE 10
SHIFTOUT 6, 5, MSBFIRST, [volume_1\8,volume_1\8]
PAUSE 10
HIGH 7
Should it work this way or am I misunderstanding something? Or do I need to check my perfboard for the 50th time?
The datasheet can be found here.
volume_1 VAR Word
volume_2 VAR Word
volume_3 VAR Word
DIRL = %11100000
DO
volume_1 = %0001100100011001 'both channels step #25
LOW 7
PAUSE 10
SHIFTOUT 6, 5, MSBFIRST, [volume_1\16]
PAUSE 10
HIGH 7
PAUSE 2000
volume_2 = %0100101101001011 'both channels step #75
LOW 7
PAUSE 10
SHIFTOUT 6, 5, MSBFIRST, [volume_2\16]
PAUSE 10
HIGH 7
PAUSE 2000
volume_3 = %0110010001100100 'both channels step #100
LOW 7
PAUSE 10
SHIFTOUT 6, 5, MSBFIRST, [volume_3\16]
PAUSE 10
HIGH 7
PAUSE 2000
LOOP
Old 22nd March 2006, 03:17 AM   #2
paulb is offline paulb  Canada
Can you get access to a digital scope? It's always nice to see the bits coming out.
Old 22nd March 2006, 06:36 AM   #3
I don't have a scope, but is there PC software that can do that?
Old 23rd March 2006, 03:29 AM   #4
I had a bad pad on cheap RatShack board. Those things get loose with the slightest amount of heat. It was shorting out when it was in it's housing. It is working alright, now. Just have to figure out to get it to step with my rotary encoder.
BTW, I am interested if anyone has a reccomendation for a DIY PC oscilliscope.
Old 23rd March 2006, 10:42 AM   #5
ALBQ is offline ALBQ  United States
Default PGA2310
Xlrator,
At a glance, the code segments and timing look correct. My first though would be to make sure you have everything connected correctly. You can do this by eye and by extending the delay times in your code, you can check the signals using a meter. See attached thread for a working example. If still problems, private mail me and I will help.
Good luck -ALBQ
DIY Remote Control for Everyone
gillespie147 (at) comcast (dot) net
Old 23rd March 2006, 12:23 PM   #6
jackinnj's Avatar
one thing which the Stamp (or the BX24, or PICs like the PIC 16F84) likes is to NOT allowing any of the data pins to float, and for noise reasons, it is wise to decouple the data lines (Clock, Chip Enable and SDO) with resistors. I have used 10k resistor arrays for this.
Instead of the value MSBFIRST try using the numeric 1.
Have you used the deboogger to look at the data lines -- interesting D*E*B*U*G is a prohibo in DIYAUDIOLAND
since you don't have a scope, you can attach a 270R resistor to a LED on each of the data lines and make sure that they are doing what they are supposed to be doing -- just insert PAUSE 250 statements.
also -- devices like ADC's DAC's and digital pots can be a bit squirrely on wiring and deocupling and groundplanes -- make sure that the power pins on the PGA2310 are decoupled with 100nF ceramic caps.
LC Audio is not responding with support BMW850 Class D 3 25th November 2010 02:01 PM
PGA2310 - Basic Stamp Troubles ALBQ Digital Source 2 8th December 2004 04:31 AM
Basic Stamp Forums starting up at Parallax jackinnj Solid State 0 26th July 2004 08:12 PM
PGA2310 + BASIC stamp HooRide Digital Source 4 20th April 2004 07:05 AM
Page generated in 0.08534 seconds (77.27% PHP - 22.73% MySQL) with 11 queries
