Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
generate jitter test signal and measurign jitter using AP2?
Old 3rd September 2010, 08:54 PM   #11
Tenson is offline Tenson  United Kingdom
Digging up an old thread. I downloaded the J-TEST file and ran it through my DAC and FFT'd the output, but I don't really understand hat to look for. Can someone explain to me how to read this and calculate the jitter?
Do I just look at the two direct side-bands of the 11025KHz signal, or is there more to it?
Here are my results.
Old 1st November 2010, 02:07 PM   #12
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
cMP² | CMP / 03Jitter
The above contains references and formulas.
http://www.stereophile.com/digitalpr...rs/index4.html
This from stereophile has some practical data and interpretation.
Well, the two highest sidebands will likely determine the overall jitter level (looks like around 400ps PP eyeballing it, decent enough for 14 Bit digital...).
On the other hand RMS and/or PP Jitter measurements relate to it's audibility about the same as single number THD Measurements do.
It seems your DAC also has a lot of 50/100Hz Hum (and upper harmonics), worse than my TDA1541 DAC with Tubeoutput stage (which is not particulary quiet) and higher jitter as well.
Ciao T
generate jitter test signal and measurign jitter using AP2?Hide this!Advertise here!
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
Jitter test signal - 11025+229.6875hz. How to ? percy Digital Source 5 25th April 2007 12:13 AM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
Damping transports to kill vibrations sounds and improve signal (jitter)? halcyon Digital Source 6 24th March 2004 08:16 PM
Listening for jitter, s'phile test CD2 - ??? Matt MacBeth Digital Source 15 12th November 2002 11:30 PM
