Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th November 2002, 01:37 AM   #1
Default what other mods should i do? Philips CD880
Post #2 for me. I read a previous post about modifying a Marantz CD80, but what about a Philips CD880?
I've done the no-oversampling and updated the tda1541 to a crown version.
What other inexpensive mods could a novice do next? Replace some of the capacitors? Replace the op amps?
The 4 op amps in it are NE5532P. Not sure what would be a drop-in replacement. ?
Any "suggestions for dummies" (especially those that point to any websites with easy to follow instructions) are appreciated.
THANKS
Loomis
Old 14th November 2002, 01:58 AM   #2
Vivek is offline Vivek  India
While we are at it, how about some suggestions for modifying Philips CD165?
Vivek
Old 14th November 2002, 10:58 PM   #3
diyAudio Moderator Emeritus
jean-paul's Avatar
Hello Loomis,
What's the point of asking if you give the answer yourself !?!?
Try making a better supply by putting an extra transformer in for analog supply. Replace the NE5532's for something sonically better like OPA2604. Yes I know they are a bit noisier but that's something you don't really hear as a difference from the NE5532.
Feed the opamps with + and - 15 V if they aren't already.
Replace all electrolytics with newer types. CD880 is old and caps of more than 10 years old aren't optimal anymore. Doesn't necessarely have to be Black Gate. BCComponents make good ( but not the best ) quality too.
Replace the crappy regulators for LM317/337 or better.Retrace the ground traces.
Put a better 11.289 MHz low jitter clock in it like Guido Tent's or Elso Kwak's. This again is the mod that makes 50 % in terms of quality of most mods.
And best of all: read this thread: Three things you can do to make CD players sound better
It's only audio
Old 22nd November 2002, 07:10 PM   #4
tubenut is offline tubenut  South Africa
tubenut's Avatar
I have only seen 1 CD880 inside, it may have been modified allready.
High speed soft recovery diodes on the analogue supply are always a reliable good sounding upgrade.
Many of the caps in the one I saw are already Elna Audio grade or Cerafine, do not go to crazy on caps to quick if this is what is in your unit.
Better clock is always a good thing to but sticking Blu Tack or similar (kids plasticine could even work) on the crystal, or even just a rubber grommit or wrapped rubber band over it will also help. (Only diff between the Arcam alpha and the alpha plus was a grommit).
Old 27th May 2005, 03:30 PM   #5
pmonti is offline pmonti  Argentina
Default I2S in Philips CD165
Somebody can tell me if y can obtain I2S from Philips CD165 Cd Player for use with one NONOS DAC 1543??
Thanks in advance and best regards...
Old 13th December 2005, 03:23 AM   #6
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Pmonti,
what dac does a cd165 have?
cheers ab
Old 28th May 2007, 07:54 AM   #7
DAC is a TDA1545A in the CD165.
Philips CD880 mods Zoran Digital Source 85 11th January 2009 09:45 PM
what can we do on PHILIPS CD880? robo Digital Source 4 26th November 2008 02:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 12:43 PM
Philips CD880 or 960? Skorpio Digital Source 1 11th November 2006 08:57 PM
RX and TX Mods on a Philips CD880 canuck Digital Source 0 4th October 2004 01:19 AM
Page generated in 0.10463 seconds (73.79% PHP - 26.21% MySQL) with 10 queries
