| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I built a separate supply for the saa7220 but stupidly didn't heatsink the 5V regulator. The regulator got very hot, and failed I guess! I put the Saa7220 power supply back to how it was originally but now the thing does the spinning like it's going to fly thing. Now I have a fantastic spinning machine. I know where the problem is:- -the clock was damaged and/or -the saa7220 has died. I thought i'd measure with a multi-meter the voltage at the saa7220 vdd pin to ground to check the voltage. As soon as I touched the ground pin with one probe of the multimeter I could see a spark ! (between the ground, and one multimeter probe). I tested during the hyper spin up. Is this just the current that the saa7220 dumps onto the ground rail!!!! |
#2 |
The SAA7220 doesn't draw so much current that it would instantly incinerate a 5 volt regulator such as a 7805. My 7805 only has a very small heatsink on it and runs at a very reasonable temperature.
So, I think you've done something else wrong. Did you test for shorts before switching on ? What input voltage do you have to the regulator ? They usually need to drop about 3 V or so (i.e. 8 V input). Any extra above that simply produces extra heat and at some point you exceed the voltage that the regulator can cope with. Did you test that the regulator output really was 5 V before connecting it up ? David. |
#3 | |
I measured 12V input into the regulator. Quite alot to drop so heat! Upon testing the 5V regulator this evening it wasn't working. Well the player started playing music, and then stopped! I have tested the clock today, and it doesn't work. |
#4 |
diyAudio Moderator Emeritus
That SAA7220 is dead. Do you have a spare one ?
Please measure the new supply with SAA7220-like load before going on with any further changes.
It's only audio |
#5 | |
I will have a look tonight. |
#6 | |||
From reading between the lines of what you said, it appears that: When you tried it before, the player worked for a bit and then stopped. You noticed at that time that the regulator was very hot. Today it worked for a bit again and then stopped. To me, this suggests that everything is fine except that your regulator is overheating and shutting down. As the player needs a working SAA7220 and clock to make any sounds at all, this must still be working when it's got a good power supply. However, after the power supply goes out when you overheat the regulator, you're not going to be able to see anything much around the SAA7220 - including the clock. So, if I were you, I wouldn't bother butchering the board to replace the chip until I'd got a stable power supply. Have you tried simply bolting a lump of aluminium to the regulator ? If your regulator is a TO220 package 7805, the heatsink will be connected to the centre pin which is 0V, so make sure it doesn't short against anything else. If your regulator is not a 7805, what is it ? A 78L05 (tiny package without heatsink) is probably not up to the job. So far as heatsink size is concerned, you shouldn't need much and that makes me wonder if your 5V rail is being pulled down by something else. Back in 1989 I installed a 7805 with about 5 cm^2 of aluminium attached as a heatsink in my CD player to supply the SAA7220. This worked just fine up until last year when other parts of that player finally gave up the ghost. My current CD player has a similar arrangement. |
#7 |
I have just soldered the crystal back into the player instead of my clock, and took out the regulator (thanks for tips). The player now reads a disc, and sound is ok. My thoughts were that it was a clock problem probably a dry soldering joint or failed regulator on my clock module causing the player to go warp speed! I still don't understand why there was a spark! Does the warp speed cause the saa7220 to spark ? Any ideas ? |
#8 | |||
You have still not described just what you had connected to the player. It's not really possible to say much without that information. |
#9 | |
It was a 5V regulator with a 11.2896Mhz canned oscillator on a DIL socket. I was going to upgrade the oscillator to a low jitter type. |
#10 | |
I always touch the cabinet first, with my hands or soldering tip or multimeter best |
| SP/DIF out of SAA7220 | Sandor | Digital Source | 16 | 6th February 2006 03:38 PM |
| SAA7220 queries | ash_dac | Digital Source | 0 | 30th December 2005 04:46 PM |
| Removal of SAA7220 | tubee | Digital Source | 10 | 2nd August 2005 08:37 AM |
| SAA7220 / clock - ground filtering ? | Bernhard | Digital Source | 7 | 24th May 2004 02:04 PM |
| SAA7220 running hot? | Rotellian | Digital Source | 4 | 4th October 2003 09:03 PM |
| Page generated in 0.12999 seconds (82.99% PHP - 17.01% MySQL) with 11 queries |
