Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th March 2006, 07:27 AM   #11
tubenut is offline tubenut  South Africa
tubenut's Avatar
Thanks Anatech
Will see if I find the courage to strip a perfectly functioning mech to absolute hustler state....
Just need to decide if I want to hold on to this player or not...
It will have to be superior to the Theta Data Basic II (cdm9 pro) as a transport, as a player it is not as good as my Data Basic/DS Pro Basic.
AND, I need to know if I will be able to buy new lasers before it takes long term residence in my abode........
Guillaume
Guillaume
Croak Audio Exploration
Old 17th March 2006, 01:43 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Guillaume,
I don't care for the Technics sound either, seems they "mash" the sound. The easy answer to your question would be a call to the local Technics service facility. Disc motors, laser heads and suspension rubber seem to be the biggest problems. Get a spare belt while you are at it.
If the tech indicates these items are fine, get spares and the manual anyhow. Have him optimize the adjustments.
-Chris
Old 18th March 2006, 09:06 AM   #13
matski is offline matski  United Kingdom
Send a message via ICQ to matski Send a message via AIM to matski Send a message via MSN to matski Send a message via Yahoo to matski
Hi anatech,
Your advice has paid off! After carfeully following the procedure you gave me I have had two days of faultless performance. I agree with you on the "technics sound" but it does not seem to be a problem with this player. It's certainly a lot better than the SL-P777 I have, far fuller and darker silences. It's not as good as my CD2 but certainly less japanese and "electronically processed" than many others, e.g Yamaha that I also have. Now if I could just make the bass as good as on my CD104, I'd be happy!
Thanks again
Mat
Old 18th March 2006, 10:08 PM   #14
anatech's Avatar
Hi Matt,
I'm happy things are working out so far.
Improving the sound might be as easy ($$) as adding an outboard DAC. Try for a multibit type. You could take the CD player in and try them in the store, you can then compare with the built in DAC to make sure you are moving up.
IMHO the only way to modify your machine would be to bypass the D/A and analog section and install a D/A - audio board. It's a lot of work and the external DAC can move from machine to machine as required.
-Chris
Old 19th March 2006, 08:39 AM   #15
tubenut's Avatar
Hi all
Did some listening to the Acurus (Technics based mech I now assume) vs Theta Data Basic II (CDM9 pro based with various tweaks added by me).
Well, the Theta will remain my drive of choice feeding a DS Pro Basic II DAC.
The Acurus CD Player is considered a good transport by many on the net, in fact acurus talk more about the wonders of this mech then the DAC on the player literature.
In summary I would say that the Theta provides a deeper soundstage, has a subtle unforced nature and is quite lush in its presentation with lovely unforced detail and focus. The Acurus makes one sit up and take notice but it seems more HiFi, I like some of its exuberance but it gets a little more tyring on harder sounding discs. My wife says it sounds like the Acurus tries too hard in comparison.
If the discussed Technics player is anything like this Acurus, I would recommend a DAC with a mellower tone, multibit perhaps with a tube?
Guillaume
Old 11th July 2007, 08:07 AM   #16
Peavees is offline Peavees  Ukraine
Send a message via ICQ to Peavees
I keep SL-P990-
No Mash sound!
Its quad PCM56P-J
Electrical Adjustment of a laser pickup Salar Digital Source 17 2nd August 2010 05:10 AM
Arcam alpha 7 CD - replaced laser but still skipping.. Greenderek Digital Source 6 29th June 2010 11:32 AM
Laser pickup adjustment on Accuphase CD player Lulu_the_cat Digital Source 1 24th January 2010 01:54 PM
Krell DVD Standard laser adjustment ECM Digital Source 6 1st January 2010 07:18 PM
need help with CDM4 laser adjustment vubkevin Digital Source 2 23rd August 2009 10:26 PM
Page generated in 0.09146 seconds (76.05% PHP - 23.95% MySQL) with 11 queries
