Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th March 2006, 07:36 PM   #1
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default Philips DVP9000s unconscious
I tried to update the firmware of this player.
The receipt is here:
http://www.avsforum.com/avs-vb/showt...t=philips+9000
But I suppose that this update is only suitable for the European version. Mine was bought in Singapore (no scart). After I tried to power up the machine after updating it switches off immediately.
Does anybody have an idea how to cure this ?
I already have a copy of the service manual and there is a code to correct for the original settings. So I thought I would not have a great risk in trying to update the firmware. But if the machine does not start up at all I cannot do anything. After putting it on the wall socket I see the standby led for a second and then it switches off immediately.
Old 13th March 2006, 07:48 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
This reminds me of a badly updated motherboard bios.
Usually there is not much hope and every case will be different so you will need someone who knows these players in dept.
/Hugo
Old 13th March 2006, 08:32 PM   #3
What steps did you perform to do the firmware update ?
What happens if you hold down OPEN & PLAY or OPEN & STOP when you apply the power and switch it on (these put it into service mode) ?
Jon
Old 14th March 2006, 06:22 PM   #4
Jaap's Avatar
Jon,
I tried but it doesnot work because it does not even start with the boot sequence. I suppose I have to bring it to the Philips guys.
Old 14th March 2006, 06:32 PM   #5
Jaap,
I know this is a bit extreme but are you able to desolder the two flash chips and reprogram them externally? I had a look at the flash image and it appears to be an uncompressed 2MB VXWorks OS image + a 100K or so of boot loader. It should be possible to take the firmware image from the zip file and program it directly into the flash thereby restoring your player. There doesn't appear to be any other eeprom/flash device on the board or download header. I'm not sure what else Philips could do apart from swap out the whole pcb.
Jon
Old 14th March 2006, 06:42 PM   #6
diyAudio Moderator Emeritus
jean-paul's Avatar
You learnt the very important lesson that you should flash european versions of hardware with their european firmware-version.
Most people only need one lesson to fully understand the matter
Good luck with the machine, I think it will cost you much effort to bring it back to life.
It's only audio
Old 14th March 2006, 06:51 PM   #7
Jaap's Avatar
Thanks for the suggestions.
The machine should have a rs232 connection somewhere, so I suppose the Philips service people can connect a service PC to the player and load the software it needs
Old 14th March 2006, 06:56 PM   #8
Jaap,
True but there would need to be some firmware on the player to enable it to 'listen' to the serial port and download new firmware (just as there needs to be some firmware to read the CD and reprogram the flash). If it's not even switching on I suspect this is a lost hope.
Jon
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
Troubleshooting and upgrading the Philips DVP9000S elp_gr Digital Source 2 1st August 2010 08:12 PM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips 477 imix500 Multi-Way 3 23rd June 2005 06:47 AM
Philips CDM-3 Angelm Digital Source 1 31st March 2003 04:52 PM
Page generated in 0.08968 seconds (74.83% PHP - 25.17% MySQL) with 10 queries
