| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
This is something I can't quite understand. Digital sources have a master clock in them usually in the form of a crystal oscillator. In my cdplayer's case this is 27Mhz.
What is the relationship between this clock and the system clock of a DAC (i.e. the MCLK line in an I2S signal) which is not 27MHz IIRC. While on these relationships at what frequency is S/PDIF clocked? And how does this mess relate to the frequency of the digital audio (44.1khz 48khz 96khz etc) |
#2 |
Your cdp can not be 27Mhz as it has a 44.1khz base only. A dvd player has a 27Mhz clock to handle the video processing.
The pic shows typical relationship between bit, word and data. |
#3 |
Clock vs sampling freq
#4 |
Ok so can you tell me how the clock is derrived from the 27Mhz crystal oscillator that I replaced with a 27mhz Tentclock? (indeed it is a dvd-audio player). But the tentclock also re-clocks the S/PDIF output through a flipflop no doubt. How would that work since the result is 27Mhz.
#7 |
You must mean other then getting all samples exactly right
#8 | |
Banned
I just tried it!
#9 |
IMHO asynchronous reclocking doesn't work.
Synchronous reclocking however I found (did this to the output of my cdplayer) yielded a slight bit of improvment. That said my standard source was a shocker to begin with
#10 |
Hey A8 thanks for that link it obviously explains that a cdplayer can derrive it's audio/video clocks from a 27Mhz crystal.
But i'm still at a loss as to how S/PDIF then propegates at 27Mhz if that is not an audio frequency. I could be way off the mark but it appears that the S/PDIF output of a Tentlabs XO-3 reclocker runs at the frequency of the crystal itself. |
| different clocks in one DVD player | spendorspain | Digital Source | 6 | 7th June 2008 09:55 AM |
| I'm confused with Clocks | jkeny | Digital Source | 14 | 25th April 2008 01:46 PM |
| Audio Clocks | quiller | Digital Source | 12 | 2nd January 2008 02:28 AM |
| The digital system - On clocks, x-ports, S/PDIF, DAC's, etc | PBeyer | Digital Source | 32 | 2nd October 2005 08:41 AM |
| Clocks | hacknet | Digital Source | 9 | 21st June 2004 08:52 AM |
| Page generated in 0.09651 seconds (77.04% PHP - 22.96% MySQL) with 11 queries |
