Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th March 2006, 10:59 PM   #11
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Thanks for that. It's time for bed now, but I will read and inwardly digest tomorrow.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th March 2006, 11:11 PM   #12
Banned
Send a message via Yahoo to Elso Kwak
Originally posted by andrei
Take a closer look at the phase noise measurements of Linrad oscillator - they are exceptionally good. Elso, if you have measured the phase noise of your clock, I would love to see it, especially if you think they are better.
I guess I am enjoying an institutional subscription... Here is the direct link to the paper.
I only listen.....
Guido measures too......
Old 9th March 2006, 11:12 PM   #13
Banned
Colpitts have superior phase noise according to the literature
Old 10th March 2006, 01:17 AM   #14
andrei is offline andrei  Canada
Originally posted by Elso Kwak
I only listen.....
Even if you design your stuff by ear, there is no excuse not to measure the end result (even if it is just to try to understand why it sounds good). Unless you cannot do it, of course...
Old 10th March 2006, 06:30 AM   #15
Banned
Question measurements
Oh there we go again.
Why, understanding that comparator B sounds better than comparator A?
And I don't have the money for that kind of equipment......
Old 10th March 2006, 10:22 AM   #16
EC8010's Avatar
Sadly, the equipment that enables jitter or phase noise measurement is horrendously expensive - that's why when I first looked into this I had to attack the problem from theoretical first principles, knowing that I would not be able to measure, only listen. I did come up with a circuit involving a four-quadrant multiplier for amplitude stabilisation and low impedance drive to the crystal but I never got around to building it properly.
Old 10th March 2006, 05:02 PM   #17
Bernhard's Avatar
According to some papers, jitter causes nonharmonic sidebands, so jitter could be detected indirectly with other equipment { [ ( ) ] }
Old 10th March 2006, 08:57 PM   #18
Default Re: measurements
There we go again indeed... You do not need expensive equipment to measure phase noise - read about it at Wenzel's website. I imagined that as a resident clock expert, you knew these things.
Check out this oscillator circuit which features amplitude stabilization to produce high-purity sine wave. Maybe it's something like you had in mind. OTOH, high harmonic purity does not necessary imply low phase noise floor...
Old 10th March 2006, 09:28 PM   #19
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Re: Re: measurements
True ... but you do need a reference oscillator !
Old 10th March 2006, 09:43 PM   #20
Default Re: Re: Re: measurements
No, just run two samples of the same oscillator - random phase noise from both will add. Even PLL probably can be omitted. Just feed two free-running oscillators into a mixer followed by a low-pass filter/buffer, and inspect the resulting beat spectrum with a sound card/FFT software.
Tapping master clock habsrock93 Digital Line Level 10 8th November 2008 01:41 AM
CD master clock ftp838 Digital Source 38 18th December 2004 10:22 AM
Master clock of Marantz SA8260 hatasa Digital Source 7 29th January 2004 09:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
