Go Back   Home > Forums > Source & Line > Digital Source
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 8th March 2006, 08:43 PM   #1
Lyra is offline Lyra
Lyra's Avatar
Question 24 to 18 bit conversion ???
Is it possible to take a 24-bit (or 20...) left justified or I2S timed signal (LR alternating) and convert it to 18-bit Left Justified MSB-first (LR alternating) ?
I have been looking around here (...and the web....) without any information around this "problem"
Lyra
Old 8th March 2006, 09:16 PM   #2
Default Re: 24 to 18 bit conversion ???
Lyra
It is a simple task that depends to certain extent on the source but why would you choose to truncate 6 bits?
Old 8th March 2006, 09:38 PM   #3
Lyra's Avatar
I want to truncate the signal because I want to replace a defective and obsolete! AD-converter.
The original AD-converter deliver 18-bit, but there arent so many (if any) 18-bits converters available, and the rest of the circuit expect 18-bit...and wouldn't/ couldn't handle more bits.
24-bits AD-converters on the other hand.....is widely available.
So...how do I manage to trunkate the signalflow from one newer and relatively good AD-converter ?
Lyra
Old 9th March 2006, 12:41 AM   #4
With I2S and left justified data, wordlength does not matter as excess bits are simply ignored.
Old 9th March 2006, 05:52 AM   #5
Francis_Vaughan's Avatar
Truncation would not in itself be difficult. A small PLA, or a handful of logic chips. On the other hand the audio will not take kindly to simple truncation. You must dither the signal again to decorrelate the new least signignificat bit. Otherwise it will not sound good at all. Doing this well is not trivial.
Edit:
Hang, on - you want to do the opposite. this should be fine - a 24 bit DAC will usually pad out and work OK.
Old 9th March 2006, 08:48 AM   #6
Send a message via AIM to Rescue Toaster
Francis, it's an ADC not DAC.
I think the problem is a 24 bit ADC might be operating at a different bitclock than the 18 bit was. IE, it possible but it might not be easy. If the old 18 bit ADC padded out to 32 bits (thus 64 bitclocks per wordclock) it should be easy. If it did something funny and run at like 36 bitclocks per wordclock it would be pretty hard.
Can you post part numbers for the old ADC chip and the next chip in the line? (whatever the ADC is sending it's data to)
Old 9th March 2006, 10:15 AM   #7
Oops... Should read closer.
OK, dither is a problem. And indeed bit clock rate - that could be fixed - but the dither is not easy.
Old 9th March 2006, 10:24 AM   #8
Lyra's Avatar
The SM5847 (or similar) do some of the work I think, but the format out is on separate pins....and it should be on the same pin altenating with the L/R signal....
Am I way out here, or could this be a part of the sollution ??
Old 9th March 2006, 10:43 AM   #9
Lyra's Avatar
The old chip is a CS5389-KP, and it sends the data into the DSP in an Lexicon PCM90 (via a 74HC08), and I am quite sure that I can do nothing with the way the DSP expects the signal...it's way to complicated to alter !!?
I am posting a zip-file containing a piece of the Data Output Timing chart regarding the old AD-converter the way I think it is used in this perticular equipment
Old 9th March 2006, 11:02 AM   #10
Just about every audio ADC runs SCLK at 64Fs in at least one format and so long as the CS5389 you are replacing was set to I2S or Left justified data, the wordlength will take care of itself.
From audio quality POV though, simply chopping off 6 bits is less than ideal. The SM5847 will not, however, solve your problem. It is an oversampling filter and I doubt the circuitry downstream from the CS5389 was designed to cope with 8x oversampled data.
If you cannot find an 18bit dac try a 16 or a 20 bit one. The PCM1801 and PCM1800 from TI are current production 16 and 20 bit dacs respectively. TI also have an 18 bit dac but it is considerably more expensive than any other ADC and requires an external decimation filter.
Thread Tools
SVC to DVC conversion madstamm Subwoofers 8 13th January 2008 05:45 PM
dB/W/M conversion - M vs 0.5 M ?? MadMutt Multi-Way 3 26th December 2007 01:51 PM
9v to 12v conversion purprobe Parts 2 17th September 2005 10:37 PM
rca conversion oogared Tubes / Valves 3 3rd September 2005 06:48 PM
PCM to DSD conversion liz Digital Source 6 2nd October 2003 09:53 AM
Page generated in 2.11434007 seconds (98.10% PHP - 1.90% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
