| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've posted about my faulty Marantz DR6000 before, I wonder if anybody has any ideas what could be wrong with it...
The unit passes the "self test" which is obviously a start but the cd tray doesn't open. When powered on there is a degree of friction on the tray [ie. if you try and push the tray in or pull it out it resists - there's no resistance when powered off]. What's more, the natural state of the display is to say "open". If i then press the eject button it reads "close" for about 10 seconds and then returns to "open". Is there a sensor on the CD tray that might be faulty and could be replaced? Any help would be greatly appreciated. Ta |
#2 |
If the tray motor is running and trying to close the already closed tray it's probably the sensor (assuming there is no broken belt).
Usually a microswitch on the fixed part that is mecanically driven by the tray; may be one switch for both open and closed sensing. |
| denom pma250 amp faulty,but no faulty parts found please help | homertooties | Solid State | 1 | 7th December 2008 03:58 PM |
| On/Off sensor with LEDs | theshame | Parts | 6 | 21st December 2007 11:47 PM |
| Proximity sensor | DWBH | Everything Else | 21 | 11th November 2007 04:23 AM |
| Tilt Sensor | Devil_H@ck | Everything Else | 2 | 7th January 2005 05:18 PM |
| Second driver as MFB sensor? | Mr Evil | Multi-Way | 14 | 24th August 2004 09:47 PM |
| Page generated in 0.06655 seconds (70.93% PHP - 29.07% MySQL) with 10 queries |
