| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am looking to use a passive I/V with a TDA1541a and then an opamp for gain. The top version on the attached schematic is what I was thinking of doing, the bottom version is stolen from hagtech (sorry Jim) and uses this concept but with a bit of filter. Jim's original, however, is for a PCM1704 which may have different requirements form the TDA1541A.
So, the questions: - do I need the filter (is it a good idea?) and if so how do I figure out the component values, - do I need to AC couple the DAC to the opamp (i.e., is this a difference between the philips and BB chips) since there is offset, and - is there anything else I should do here? Thoughts? -d |
#3 |
Thanks, that is helpful.
I am wondering about a few other things, however. My primary question is about whether I can direct couple to the opamp, or if I need to block the offset from getting to the opamp. It seems that it should be low enough that I can safely ignore it and do the blocking on the output, but I feel like I should get some confirmation on this. Second, with tda1543 based DACs I never worry about the filter. Is it more necessary here, or can it be safely ignored? Last, Jim uses a resistor in series with the opamp's input. Is this necessary? |
#4 |
From Phillips TDA1541A datasheet, Iout from pins 6,25 is refered to ground, and zero scale current is < 50nA. So it looks like you don't have to worry about offset.
#5 |
You will have 2mA flowing thru the passive I/V resistor when there is no signal.
So you only need a coupling capacitor after the opamp. A 3rd order LPF is often used when oversampled. Haven't tried the TDA1543 yet. Anyone have some to spare? Tom EE |
#6 |
Few days ago & tweaked Onkyo dx-6720.It has ad1860 dac(output current 1mA).& used 100 ohm Allen Bradley resistor for i/u and parralel 18nF Wima FKP.After that AD825 (non inverting 100 ohm and 2k).Max output 2V, 1,8 V at 20kHz.No any hum even without capacitor.Connected to battery powered gainclone and loudspeakers with Seas .Every filter only reduces quality.At the output about 5 mV so no need decoupling capacitor too.You only need to use good resistor for i/u conversion and try different values.With small values(10-40 ohm) less distortion and mainly second(more analogue sound) with bigger more dynamics and opamp works better.
Tda1543 & use without any filter. |
#7 |
Another idea, assuming that I do want to strip off high frequency noise, would a cap across the opamp's feedback resistor be an okay way to do this, as opposed to the cap, resistor, inductor method above?
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| passive pre amp | mschwilson | Solid State | 10 | 27th July 2005 01:43 PM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Help with passive pre | sejarzo | Everything Else | 9 | 27th April 2004 06:11 PM |
| Passive EQ? | Johan_Ch | Everything Else | 1 | 4th September 2003 04:11 AM |
| Page generated in 0.09584 seconds (80.91% PHP - 19.09% MySQL) with 11 queries |
