Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Pick-up replacement
Pick-up replacement
Old 7th March 2006, 07:25 AM   #1
Subcat001 is offline Subcat001  England
Subcat001's Avatar
Default Pick-up replacement
Hi all
I recently purchased a 2nd had Rotel RCD-02 CDP. Unfortunatly I discovered it had playback problems. Some CDs would suffer jitter as well as it being selective of which discs it would playback. My friend and I decided it was most likely to be the CD pick up, so I ordered two KSS213Cs(as specified in the service manual) from CPC. We have now fitted both modules and neither appears to work. Both post "NO DISC" error. Though replace the orignal pick-up and everything's fine, albeit with its original traits. I
am I missing something blindingly obvious??? Or have I got two dud modules?? Or is it that there are variations on the said pick-up???
Cheers
James
Old 7th March 2006, 01:02 PM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I'm not familiar with that laser assembly but check for anti-static solder blob that has to be desoldered. Make sure you take anti-static precautions when changing the laser assembly.
No longer DIY active
Old 7th March 2006, 02:26 PM   #3
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
You have to desolder the blob indeed.
It's only audio. Member of the non modular PCB design committee
Old 7th March 2006, 09:47 PM   #4
Subcat001's Avatar
Thanks for the replies guys. Discovered a solder blob on two pads on the PCB. De-soldered and bingo!! So all is working again and it appears to have cured all the read and jitter problems.
Cheers for help
Old 8th October 2012, 06:11 PM   #5
LEET2012 is offline LEET2012
Default How to fit the above laser assembly?
You mention a solder blob, could you say exactly where this is & are there any cables to solder, do you have to unattach any cables to take out the assembly to be replaced, also is it an easy thing to fit as i have never done this before.
Lee.
Old 8th October 2012, 06:14 PM   #6
Mooly's Avatar
Pick-up replacement
It's on the pickup and should be fairly easy to see. It just shorts the LD out for static protection. The KSSxxx pickups all plug in with no soldering.
Old 8th October 2012, 06:51 PM   #7
Cheers, thanks for the info, if only for a photo guide on how to do this, this would save me a bundle if i could fit it myself, do you know of anywhere there may be a photo guide on this.
Many thanks, Lee.
Old 8th October 2012, 07:13 PM   #8
Mooly's Avatar
Pick-up replacement
Can't recall any specific guides but the KSS pickups are usually a doddle to change... as in minutes. Its all straightforward mechanical disassembly.
Old 9th October 2012, 08:32 AM   #9
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
perhaps this helps:
http://www.monacor.de/de/FLE/KSS213C.pdf
ƒVƒ‡[ƒgƒ‰ƒ“ƒh‚‰œ•–@`KSS-213C•by‚b‚cƒp[ƒcƒ}ƒ“
Sony Bookshelf Stereo CD Repair - YouTube
http://www.datasheetarchive.com/KSM2...datasheet.html (Datasheet)
http://lampizator.eu/LAMPIZATOR/REFE...eferences.html
Pick-up replacementHide this!Advertise here!
Help me pick a DAC kuroguy Digital Source 5 28th January 2008 08:40 PM
Which cap would you pick? davidallancole Parts 11 7th December 2007 02:51 AM
troubleshooting a pick up ehous Digital Source 0 5th July 2006 02:45 AM
Luxman D-225 optical pick-up replacement chicco_36 Digital Source 13 23rd November 2005 02:10 AM
Copyright ©1999-2017 diyAudio
