| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I would like to be able to measure jitter on the coaxial output of my SqueezeBox. Does anyone here know the simplest, or preferably cheapest, way to perform this measurement?
#2 |
There are specialized test instruments for the purpose. I used to use an HP 12 Gbps jitter test set at TI to measure the jitter out of SERDES and hypertransport chips for internet infrastructure switches. Those boxes cost $300k each. I also played with some Wavecrest boxes that were sooooo sexy! They did a lot of statistical analysis and calculated jitter limits based on a sample measurement- i.e if your needed jitter induced error down to 1 per 10^20 bits, you didn't have to send 10^20 bits through the thing to see if there were any errors. Even at 10 Gbps it takes loooong time to send 10^20 bits, so being able to confirm error rate numbers with just a sample was a big timer saver. The trouble was, many clients didn't believe the statistics, so we often had to run the long tests anyway.
Unfirtunately I no longer have access to that sort of instrument... I_F |
#3 |
$300K? That's not exactly what I had in mind.
#4 |
you usually need better measurement equipment than what you are trying to measure
you can try to measure the results of jitter on the analog output I've seen noise "skirts" on test tones from a portable CD analog output measured with a Lynx sound card that were presumably caused by the portable's clock jitter looking at level/freq/load dependency could help separate DAC Vref/psrr from clock jitter induced noise in this sort of indirect measurement direct measurements of clock jitter are going to require more expensive equipment other options are good ref clocks, now noise multipliers and plls to translate the jitter spectrum to a frequency where cheaper equipment has sufficient resolution look at crystal manufacturer’s web site’s tech articles on jitter/phase noise Circuit wanted for a Low Phase noise 100MHz Clock: http://www.diyaudio.com/forums/showt...931#post295931 |
| generate jitter test signal and measurign jitter using AP2? | BJAMR | Digital Source | 11 | 1st November 2010 02:07 PM |
| affordable & easy way to measure jitter? | jerome123 | Digital Line Level | 1 | 4th September 2009 08:29 PM |
| is a resolution of 0,001 UI good to measure clock jitter ? | Bernhard | Digital Line Level | 1 | 8th December 2008 02:01 PM |
| Measure jitter with DSO ? | Bernhard | Digital Source | 0 | 17th June 2006 06:45 PM |
| Data Jitter Versus Electrical Jitter? | 300_baud | Digital Source | 8 | 16th July 2004 07:59 PM |
| Page generated in 0.07796 seconds (73.65% PHP - 26.35% MySQL) with 10 queries |
