| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I hope this is the right thread. javascript:smilie('
wink You guys seem pretty sharp, so here is my problem. I recently bulit a chipamp (form Brian Bell) and the thing has absolutely surpassed my expectations of quality and power. The problem is with my soundcard. I get a buzz/hum only when using the PC as a source. No one else notices it, nor does it effect the enjoyment of listening. But, I know it's there and it bugs me. I have made all the standard ground loop test and subsituded sources and cables to come to the conclusion that the noise is generated from the soundcard it's self. I downloaded a "freeby" analizer and found that with everything muted, the card is generating a 66htz signal at about .18 volts. This is a CHEAP built in soundcard but is the buzz a result of the switching power supply? Would a quality soundcard help or would I still get the buzz because of the power supply? How bout a USB sound card with it's own separate PSU? Thank you in advance for sharring in knowledge or experience.
Poor stereo mix? Switch to mono! Perfect. |
#2 |
Hello,
Maybe you can try to solder some condensator between the + and ground of the dac chip, if possible. If it's a built-in sound card of your mother board, it could be hard... I think the best solution for you is to buy an external sound card but with external alimentation, not powered by usb (if the noise come from psu, same problem) Hugues |
#3 |
Hugues,
Thanks. I agree about the USB card with it's own supply. Was just wondering if anyone had the same problem and how they solved it.
| Noisy ADC | 5th element | Digital Line Level | 6 | 30th August 2009 10:29 PM |
| Noisy NAD 705 | squirrel69 | Solid State | 6 | 7th April 2006 01:37 AM |
| noisy noisy noisy noisy noisy tube | dsavitsk | Tubes / Valves | 50 | 20th February 2006 04:07 PM |
| How can i use a noisy PSU ? | Garbz | Solid State | 5 | 3rd January 2004 12:15 AM |
| ESP P3A amp, very noisy | DaViruz | Solid State | 33 | 16th November 2002 06:07 PM |
| Page generated in 0.08915 seconds (63.01% PHP - 36.99% MySQL) with 10 queries |
