| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
Reading the thread speaking about discrete amp, I had an idea, but is it realisable????? Why not using the parallel port to output the audio flux in a parallel way, (ok 8 bits but mutiplexed for 16bits and for stereo, the parallel port can handle 2Mbytes/s, it will be sufficient for up to 500kHz sampling rate) make a R2R network and output the analog. What you think???? Do someone tried this??? Thanks |
#2 |
It would work and easy to write a driver for it.
We made a flash memory programmer for one of our products that used a Xilinx cpld on board to do byte to multi-word conversion from a parallel port 2M is pushing most PCs, 1MHz is more realistic. If you want the D/A to be the clock master, then you need to have a write buffer and poll the DAC to find when to send the next data, this will slow things down a lot.. but still enough for audio. The main problem is that you don't have any isolation from the very noisy PC gnd. |
#3 |
This was the first "soundcard" I've seen on a pc somewhere around '95. It was 8bit mono (just a R2R network) and there were some games that did support it.
#4 |
That brings back memories... I remember the magic when I first hooked up an 8-bit DAC to the parallel port and actually got music out of it... Anyone remember "mod" files?
#5 |
Got a MOD player on my mobile phone (P800)! The kids love that thing playing tunes from sesame-street
GuidoB |
#6 |
Unfortunately I doubt you can get a stable data rate on the parport. Desktop os'es are not realtime. And giving that a usb dac is a couple of bucks I don't see a point either.
PS: after .mod I recall .s3m files... man they sounded good when a friend got a Gravis Ultrasound card which had wavetable and hw mixing. |
#7 | |
There would be no problem making this DAC 24 bit, the TI USB DAC is 16 bit and rather ordinary performance. Trouble is that parports are obsolete and going away. |
#8 |
A pc gives you spdif and usb. From usb you can go to i2s (use the i2s output from a pcm2707 for example and skip the dac part). Now choose your favourite dac (doesn't have to be a TI if you don't like them) and feed it from whichever source it needs. Much more clean than building a buffer/clock/demux circuit from discrete parts, not to mention a winamp/whatever player plugin.
#9 |
Is it possible to stream 8 x pulse width modulation data from the parallel port.
| Sony "digital media port" | eleakist | Digital Line Level | 4 | 16th June 2009 01:53 PM |
| need help with parallel port interface programming | cowanrg | Everything Else | 3 | 31st March 2007 12:49 PM |
| Controlling a CDROM via a parallel port | juan_caliente | Digital Source | 2 | 1st April 2005 08:02 PM |
| Page generated in 0.09560 seconds (78.25% PHP - 21.75% MySQL) with 10 queries |
