Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
uh oh me thinks me killed my cdp
Old 19th February 2006, 10:35 PM   #1
spock is offline spock  Canada
Default uh oh me thinks me killed my cdp
While I had my cdp. opened up to check the tubes, I figured that I would install a couple of 8 pin sockets for the last pair of opamps on the board. (I had previously done this with the other 2 pair). While I did loose 1 solder pad, no big deal, just ran a wire to the next component on the board, checked my continuities and everything seemed ok. Well, I put it all back together with the new opamps and hit the switch. Lights up, no smoke, wait a minute for things to stabalize and hit the open button. Nothing. It just sits there showing a display of track 00 time 00 and the track list of 1 through 20> as if there were a disc of more than 20 tracks long loaded. So I shut it dowwn, pull the lid off the transport and put a disc in. Put the lid back on and same display, disc spins- no signal output. It's like the transport does not arrive at it's ready position to read a disc. Initial thoughts are that I some how fried the microcontoller chip, but I didn't even come anywhere near it. I know that it's a long shot, but any thoughts/help with my delema would be very much appreciated. I do like this CDP and after various mods the sound is very much improved over the stock version-until now!
Old 19th February 2006, 10:48 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi spock,
With any luck, you only blew a semi fuse. What transport is it?
-Chris
Old 19th February 2006, 11:06 PM   #3
poynton is offline poynton  United Kingdom
poynton's Avatar
HI.
You did put the opamps in the right way round??
Andy
Old 19th February 2006, 11:49 PM   #4
I believe that it is a Matsushita transport. It has CD2 marked on it. The player is a QDS-15 which is the OEM of the Norh CD-1. Here goes showing my lack of electronics skills: What's a semi-fuse?
And, yes I did put the opamps in the right way round. They are in the analog section, which is why I am puzzled.
Old 20th February 2006, 12:06 AM   #5
anatech's Avatar
Hi spock,
A semi-fuse looks like a transistor but only has two legs. They blow extremely quickly. No flash and most people are not aware they exist. Common in CD players.
-Chris
Old 20th February 2006, 12:20 AM   #6
Thanks Chris; so if upon searching for one of these two legged devices I find one that does not show continuity between the two legs I can assume that it has failed?
I guess I'm like most people-I had no idea.
Old 20th February 2006, 12:33 AM   #7
anatech's Avatar
Hi spock,
Yup. It's dead. They are called ICP protectors. They come in two case styles.
Don't worry, many tech's don't know they exist. That's what I meant.
-Chris
Old 20th February 2006, 12:37 AM   #8
Hi Chris,
I'm thankfull for your patience. The two case styles would be?
Old 20th February 2006, 03:08 AM   #9
anatech's Avatar
Hi spock,
No problem.
The first type has a TO-92 case using the two outer leg positions. The other is that small rectangular Janaese style with a "round" taken out of what would be the emitter end. Very short legs on the latter style. They are interchangeable.
If you really get stuck, I'm in Georgetown. I don't know how far that might be from you.
-Chris
Old 20th February 2006, 03:32 AM   #10
Georgetown is only about 1.25 hrs from me. It is very generous of you to offer to help me out. I may just take you up on it.
uh oh me thinks me killed my cdpHide this!Advertise here!
Amp thinks it's a receiver ?? bereanbill Tubes / Valves 8 4th June 2009 01:50 AM
Killed my T-Amp? JWFokker Class D 3 28th March 2007 07:54 AM
Speaker ignoramous thinks about ovals jmikes Multi-Way 1 9th November 2004 10:01 PM
I just killed my amp - please help me! schnitti Solid State 8 15th September 2003 03:00 AM
Copyright ©1999-2017 diyAudio
