Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th February 2006, 12:24 PM   #1
klitgt is offline klitgt  Denmark
klitgt's Avatar
Default Can OPA627 short output to ground?
I have got a second-hand Denon DCD2700 CDP for nothing, it's in a good mechanical condition and should be worth giving some other opamps than the uPC4570 ones. The BA15218 for filtering will be replaced by SSM2139, the ones that are in the DCD S1.
I have a number of OPA627 on adapters (for pin-compatibility) that I plan to use, also for the output buffers. They do not have any DC-offset and I may remove the coupling cap in each channel (marked red in attachment).
But after the cap there is a 150 Ohm resistor and then a relais that shorts signal to GND during Stop & Pause. Will the OPA627 tolerate to be shorted to GND at the output? There is no information in the datasheet as far as I can read.
I guess it will not fry because of the 150Ohm resistor and because current will be low also as the DC offset is next to nothing.
But rather be safe than sorry , so I ask the experts!
Old 17th February 2006, 07:25 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
That won't be a problem. Have no fear. I use 47 or 100 Ohm mostly for termination at that spot and I never experienced broken opamps. OPA627 is also short circuit protected....
It's only audio
Old 18th February 2006, 08:58 AM   #3
klitgt's Avatar
Thank's a lot, I will go on!
Old 19th February 2006, 06:15 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
You can go for 10 ohms.
Old 19th February 2006, 09:53 AM   #5
klitgt's Avatar
Any reasons for going that low? Please explain pros/cons with resistor values at this point, I do not really understand why there is such a wide margin. The default value is 150 Ohms.
Old 19th February 2006, 10:02 AM   #6
200r output impedance allows for medium capacitance of interconnects.
60r would allow for very long cables as in pro sound systems.
Some domestic go as high as 1k0 but these suffer from hi freq roll-off when shortish cables (2m) are used
regards Andrew T.
Old 22nd February 2006, 08:05 AM   #7
klitgt's Avatar
Of course! It is the values in the R/C coupling that determines the cut off frequency of a low pass filter. Thank's for reminding me
Old 22nd February 2006, 09:06 AM   #8
There is a compromise. A higher value of series resistor isolates the opamp from the cable capacitance and prevents oscillation.
Cyrus 2 no output after short fall WNR Solid State 6 11th May 2008 01:10 PM
Short the Output of an Aleph X rsbay Pass Labs 9 24th November 2006 01:40 PM
Short circuit output protection scheme tool49 Solid State 6 14th November 2005 07:57 AM
speaker protection and output short patriz Chip Amps 3 10th January 2005 03:55 PM
Adcom GFA 555-II- Didn't like short on output :-( Magura Solid State 3 17th November 2004 02:17 AM
Page generated in 0.08411 seconds (77.87% PHP - 22.13% MySQL) with 11 queries
