Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th February 2006, 09:58 AM   #1
spavleski's Avatar
Send a message via Skype™ to spavleski
Default PCM1704 with Lundahl LL1588?
I'm waiting delivery of 2 X LL1588 in order to put them as DAC (PCM1704 ) output after first OPA627 - I/V converter.
- Schematic attached.
- Any hint/comments ? (Ok/Not Ok, better ideas?)
Thanks,
S.P.
Old 15th February 2006, 02:05 PM   #2
nicoch58's Avatar
http://www.audiodesignguide.com/cdplayer/dac.html
I hope help you!
ciao
Old 16th February 2006, 01:04 AM   #3
Francis_Vaughan's Avatar
I assume you are simply looking for a balanced output, but also trying to use the natural high frequency rolloff charateristics of the transformer to replace the reconstruction filter.
Just seems a pity to go to all this trouble and still leave the op-amp I/V in place.
Old 22nd February 2006, 12:19 PM   #4
spavleski's Avatar
Thanks for your comments.
I've just put transformer after OP I/V and sound is OK.
Could there it be better solution - I don't know - maybe ?
Old 22nd February 2006, 05:36 PM   #5
nicoch58's Avatar
http://digilander.libero.it/paeng/magnetics_frame.htm
is possible complete passive out stage ...hope.... r i/v and trafo
Old 23rd February 2006, 07:52 AM   #6
spavleski's Avatar
I've tried to bias I/V OPA627 in class A with 8mA (using BC107B as current source).
And... sound improves gradualy!
Now thinking, is this the best operating point for OPA627 in class A ?
PCM 1704 is giving Iout +, - 1,2mA so, to be able to use passive I/V (resistor) + transformer, transformer have to be step-up type, that I don't have (at the moment) ...
Old 24th February 2006, 11:48 AM   #7
There is no reason why you can't add gain after the transformer - with an op-amp if you like. This way around you will avoid the range of issues that may beset using the op-amp as an I/V - and use it for a job to which it is much more suited.
Old 27th February 2006, 11:59 AM   #8
spavleski's Avatar
Thanks Francis - great idea! I'll try that.
Non Oversampling with PCM1704 Fabian Digital Source 8 11th August 2011 12:17 AM
PCM1704 @ 192Khz possible? jeje Digital Source 6 19th July 2008 08:55 PM
non OS pcm1704 hugobors Digital Source 12 1st March 2006 09:07 PM
Where to buy PCM1704? m_buzzi Digital Source 3 11th November 2004 12:53 PM
Pcm1704 hacknet Digital Source 5 11th April 2004 09:25 PM
Page generated in 0.09679 seconds (74.00% PHP - 26.00% MySQL) with 11 queries
