Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th February 2006, 06:38 AM   #1
wf1318 is offline wf1318  Hong Kong
Unhappy Can anyone help me to build a Optical in to USB out converter?
Hi!
As you know that many PC motherboard is already build-in with
sound card but not many have a optical in.
And I don't want to add a PCI sound card to my PC
because the motherboard have this function!
So, I want to build a "optical in to USB out converter" for my PC.
Does anyone have the experience to build this circuit or
having the diagram of this circuit or other suggestion for me?
I'm just want to record MD via optical to my PC!
Please help me!!!
Old 10th February 2006, 12:19 PM   #2
Check first if you do not have spdif in/out on a motherboard connector - many motherboards (including mine) have one, only the rear bracket with the matching connectors has to be ordered as an option.
Old 10th February 2006, 08:38 PM   #3
I thought that MD players don't have SPDIF outputs because of copy-protection reasons.
You could use an "optical" to coax SPDIF converter and feed it to a PCM2906 chip. I know that some people already built coax SPDIF to USB converters with that chip so I think that a little bit of searching has to be done to find one of the schemes. I think that there's one on diyhifi.org
Antoine
http://dmsaudio.ca/
Old 11th February 2006, 05:11 AM   #4
Thanks for your suggestion first "DragonMaster"!
Infact I already have a circuit called "Copy bit inverter" that can
slove the "copy-protection" problem of MD.
I have searching the web about the circuit I want but all of that
circuit just only have spdif / optical out and not in.
So, if anyone know where can I find a cicuit that contain
spdif / optical in with USB out to PC, please let me know.
How to build a tubed I to V converter ? Yvesm Digital Line Level 6 6th May 2009 04:55 AM
Optical 2 S/pdif converter? Ryssen Digital Line Level 21 29th January 2009 11:05 PM
FS: Digital Signal Converter- Optical in Coax Out akunec Swap Meet 0 16th May 2007 07:04 AM
Qustion: Optical/Coax to analog converter? roger-k Digital Source 1 20th December 2005 08:57 AM
I Want To Build A Very High Quality A/D Converter BillyJoeJimBob Digital Source 25 6th August 2004 07:40 AM
Page generated in 0.07043 seconds (71.25% PHP - 28.75% MySQL) with 10 queries
