| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm wondering if it's possible to build (DIY) an USB DAC/soundcard with 2 inputs and 2 outputs with a DAC with a sampling frequency of 192Khz. Has anyone tried to do something close? |
#2 |
No one has ever tried it, right?
#3 |
It's easy to make a 44.1/16 DAC using a PCM270x/290x chip from TI - these include the USB interface and software layer, isochronous clock recovery and everything and they're natively supported by Windows.
No such publically available chip exists for 24/192 right now, and I don't believe that the Windows USB soundcard driver supports these high sampling rates anyhow. This means building lots of custom hardware (think Cypress USB chip, separate PLL, PLD for handling I2S/SPDIF reformatting, etc), writing your own soundcard driver for windows, and lots of other evil things. It's a ton of effort. Best to wait for TI to come out with a successor to their USB audio chips. |
#4 |
gmarsh, thanks for your reply!
There are some commercial USB sdcards that allow 192Khz, but I've never seen a DIY one either! How do the more usual 44,1khz using a PCM270x/290x chip from TI sound? How do they compare to commercial soudcards? |
#5 | |
#6 |
dsavitsk, thanks for the link!
How does this DIY sdcard compare with commercial sdcards in terms of SQ? You say that I could build that sdcard just tu use its S/PDIF output and use an external high quality DAC, right? Has anyone tried it? Are there rumors that Texas Instruments are gonna lanuch a new generation of USB audio chips? |
#7 |
#8 | ||
#9 |
dsavitsk, how does this DAC perform?
http://www6.head-fi.org/forums/showthread.php?t=139368 |
#10 |
I've not heard it. I have a couple of the previous versions, and they are pretty good. Here is a review I wrote: http://www.ecp.cc/gud.html
I should mention a couple of things though. It is an old review and I have learned a lot since then. I'm not quite as much of a newb as I was when I wrote the article. Compared to the one I linked above (the NOS USB DAC) the one in the review is not nearly as good. I would assume that Alf's that you linked to is a little better than the one n the review, but basically the same as it is basically the same circuit. All that is to say that it is worth looking into. You should expect it to be pretty good for the investment, but don't expect it to be a giant killer. |
| FS: Onkyo SE-90PCI 24bit/192kHz Soundcard | rjm | Swap Meet | 1 | 18th December 2008 08:20 AM |
| PCM1704 @ 192Khz possible? | jeje | Digital Source | 6 | 19th July 2008 08:55 PM |
| 24 bit/192Khz spdif ? | ashok | Digital Source | 30 | 10th October 2006 03:47 PM |
| 24 bit 192khz s/cards | 5th element | Digital Source | 12 | 11th September 2003 01:27 AM |
| Page generated in 0.10838 seconds (83.03% PHP - 16.97% MySQL) with 10 queries |
