Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th February 2006, 04:16 PM   #1
Tuliman is offline Tuliman  Romania
Default Upgrade for my DAC
This is my new DAC, it uses AD1892 and AD1865N-J, the schematic is attached.
I found it as a kit, I didn't build it myself, and I need help in order to get it started/working.
First, the input, it's not a BNC/RCA connector, there are 2 pins. I intend to use it with a CD-ROM, the distance between the two will be < 5 cm, what's the best solution for connecting the digital output of the CD-ROM to the 2 pins on the input of the DAC?
Should I remove the 2 pins and put a BNC connector in place, or just use coax cable, and solder the wires on the pcb directly?
The caps on the output, the I/V stage, are no-name, should I change then with WIMA caps, will there be an improvment?
The PSU is built-in, it uses 7505, 7912 and 7812, should I "by pass" it with my own power supply?
The DAC also has I2S input, will it sound better on I2S from the USB port and then a TI chip - like PCM2902, or with SPDIF?
Any suggestions are wellcomed
Old 13th February 2006, 08:48 PM   #2
Somebody??
Old 14th February 2006, 05:22 AM   #3
dddac is offline dddac  Germany
The 2 pins are the SPDIF input most probably. You connect a BNC or RCA connectors yourself. just 2 wires, the pins you can leave. More easy to solder
Output caps always improve the sound when better quality is used. Wima is better, Auricap or Mundorf are even more better etc etc etc. Matter of taste as well..... but for sure do this
I would get the dac work first with the other tweaks. Otherwise you better built a totaly new one...
I2S input is GREAT !! you can use now an USB to I2S converter or an other (reclocked) SPDIF receiver. On my DIY Website you can read of DIY solutions for this you can vuilt yourself. Circuits are also there.
I prefer the USB input
good luck
doede
www.dddac.de
Happy listening and building
Old 16th February 2006, 08:02 PM   #4
The output caps are 100uF, electrolytic, in parallel with a 100nF SMD cap.
Sould I keep an electrolytic cap here, but use a Sanyo OS-CON, or use a MKP cap?
Are there any significant differences between AD1865NJ and NK?
Also, the input caps - C9/10 are SMD, can I do better?
Thank you.
About the 'Big 3' upgrade.... Jexx Car Audio 3 28th July 2009 07:31 PM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
DIY help to upgrade my CV E-710's bravewink Multi-Way 3 31st December 2007 06:57 AM
What upgrade for the job? Rarkov Solid State 2 16th June 2003 05:05 PM
Page generated in 0.07417 seconds (84.44% PHP - 15.56% MySQL) with 11 queries
