| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I know very little about digital audio, and there's some thing I don't understand.
So... In a standard CD player, digital info is read from a CD. Isn't it then read to a memery buffer and reclocked and then sent off to the dac, thereby eliminating machnicaly induced jitter? |
#2 |
This is true - data streams off the CD into a buffer where it is decoded, error-corrected and output as PCM audio using a crystal clock. A servo loop maintains the speed of the CD so that the buffer doesn't over or underflow.
So theoretically, no mechanical effects (other than those causing buffer over/underflows) should introduce jitter on the output of the CD player. Though practically, electrical noise generated by the spindle motor could find its way through the power supply and affect the clock device, and mechanical "shake" could affect the clock device too. And there's probably people that believe that weird quantum effects caused by the spinning CD can alter space/time within the CD player and create jitter. |
#3 |
Thanks gmarsh
This is what I thought. Then why do we worry about mechanicaly induced jitter? - Now let me say, I have added mass and damping to CD transports and have heared, under no uncertain terms, huge improvements. So now I am realy comfused ???? |
#4 |
Typical commercial CD players have a poor quality clock, usually just a gate oscillator integrated into the decoder chip. This means that electrical noise from the servo and motor and mechanical vibration all cause fairly high levels of jitter.
The clock distribution from this oscillator to the DACs is crude too, picking up jitter on the way. |
#5 |
Banned
There used to be a doo-hickey called an Iso Drive. Worked in Philips CDPs. Basically, a big disc you put on top of the CD itself.
The sonic effects were the same as lowering jitter any other place. Mass = inertia, so that might be how it did what it did. Problem was.........Philips started using cheaper and cheaper spindle motors, and they were not stout enough to spin with it on. (I have 3 of them...........4 if you count the warped one.) Jocko |
#6 |
sooo.. You could make the ultimate cdp from even a cheep player just by adding a good clock - Right? And the quality of the transport wouldn't matter ?
#7 | |
#8 |
The transport doesn't matter as long as there are no uncorrected errors.
A good clock, dac and analog stage is all you need. Or an external jitter-insensitive dac. |
#9 |
Wolfson have published an excellent white paper on jitter here:
http://www.wolfsonmicro.com/uploads/...erformance.pdf It is interesting that jitter spoils the effects of digital filtering on out of band signals |
| generate jitter test signal and measurign jitter using AP2? | BJAMR | Digital Source | 11 | 1st November 2010 02:07 PM |
| Jitter in DAC. | ghee0 | Digital Source | 44 | 3rd June 2010 09:25 AM |
| Data Jitter Versus Electrical Jitter? | 300_baud | Digital Source | 8 | 16th July 2004 07:59 PM |
| Page generated in 0.09652 seconds (77.54% PHP - 22.46% MySQL) with 10 queries |
