| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
what are the pros and cons of tube I/V ? Is only tube amplification possible after passive I/V, or also tube I/V that keeps output pin of DAC on virtual ground ? I read about passive + tube = no feedback = no intermodulation distortion but also I read it is up to 1% harmonic distortion at FS from use of passive or tube ? Or better discrete silicone ? Just like to hear some opinions ... |
#2 |
You can't say "no feedback = no IMD". Any nonlinear system will create IMD, and this includes tubes.
If you're feeling really adventurous and want proof of this, build yourself a diode I/V (that's right, use a forward biased diode without feedback) and measure the intermodulation. I guarantee it won't be zero - heterodyne radio receivers often use diodes in this manner as mixers, and the intermodulation is what makes them work. |
#3 | |||
Magneto the Gravity Man
#4 | |
#5 |
Active or passive, both are possible.
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.08491 seconds (77.07% PHP - 22.93% MySQL) with 10 queries |
