| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've built my version of a DDDAC, and am adding a TOSLINK connector. But I don't want to add a switch to select coax or optical.
Can I simply feed both inputs into the CS8414 via separate capacitors? Obviously, I would only have one source connected at a time. Alternatively, does anyone have a suggestion for a minimal parts count auto selector that would, for example, select the optical if there was a signal on the optical, otherwise select the coax? The signal from the optical receiver is digital, CMOS levels, but I'm not sure about the signal on the coax.. can I receive it with a standard digital component, such as 74HC14? thanks, Neil |
#2 |
S/PDIF is only 500mV into a 75 Ohm load. To receive it properly, you need a proper receiver chip. Alternatively, you need a video op-amp to amplify it, then AC couple and DC restore it (to make the signal swing 0V to +5V, rather than -2.5V to +2.5V). Once you've got logic level, it should be easy enough to add some circuitry to detect which input is active and to select it.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Methods of Input Selection? | mattthegamer463 | Everything Else | 7 | 2nd December 2008 07:09 PM |
| Input potentiometer selection | koolatron | Tubes / Valves | 12 | 18th April 2008 05:04 PM |
| Input cap selection | Deltat | Parts | 10 | 12th May 2006 03:54 PM |
| Page generated in 0.06264 seconds (68.76% PHP - 31.24% MySQL) with 10 queries |
